Author Topic: Remove stock side steps (JK Unlimited)  (Read 1477 times)
Offline jeepgrl
  • All those JKs are starting to look the same...
« on: June 30, 2010, 10:36:41 PM »
I'm trying to get the stock side steps off my JK to install some body armour.  I've been able to get the undercarriage bolts off, but it doesn't seem to want to come out... any thoughts?
Current project:
2012 2-door Orange Crush JK
AEV 3.5" lift
33" Mikey Thompson MTZ
Smittybilt XRC front and rear bumpers
Warn VR800 winch
BUILT AND SOLD: Silver 2007 JKU (because they all look the same now anyway)
Offline jkrubi
Re: Remove stock side steps (JK Unlimited)
« Reply #1 on: July 01, 2010, 05:03:40 AM »
On my 2 dr there was 2 bolts  going into the frame, and 4 10mm nuts going thru the pinch seam. Once the 6 bolts were removed my steps or Rubi rails fall off.  The nuts are in the same general location as the bolt. Hope it helps. If you need I can get a pic of my steps as they are in my shed.
Offline apeman
  • not as grumpy
« Reply #2 on: July 01, 2010, 05:17:47 AM »
Getting grumpier every day.
Offline parabs
« Reply #3 on: July 07, 2010, 11:47:57 PM »
that looks like blood.  is it mandatory to use blood as a lubricant when cutting metal with a chainsaw?  If you say yes, I am not interested in chainsaw-ing with you...great pic tho.
2000 TJ Sahara - Sold
« Reply #4 on: July 08, 2010, 12:12:17 AM »
belt dressing works good as a lubricant too................
i've heard sledge hammers and sawzalls work to take off body panels........ or side steps......... rocks work too.  but i don't have rocks........ got a hammer though ;)
Offline jeepgrl
« Reply #5 on: July 21, 2010, 03:49:16 PM »
Damn... I didn't think of the chainsaw... got them off with alot of force and dremmeled the others that didn't want to come off (being a girl and all, I'm not THAT strong, and I have zero patience for these things)
Current project:
AEV 3.5" lift
Warn VR800 winch
