Author Topic: 92 YJ O2 Sensor Question  (Read 1274 times)
Offline Danger-m
« on: July 05, 2010, 06:21:39 PM »
With all the discussion about gas mileage, I have a question
When I got my 92 YJ, the O2 sensor was missing, just an empty hole ..... anyway, I did replace the sensor: But I did not notice any difference.
I read in the manual that a dealer has to replace these (reprogram), Is this correct, is the computer affected?
Tx
Dwight
Offline apeman
  • not as grumpy
Re: 92 YJ O2 Sensor Question
« Reply #1 on: July 08, 2010, 03:13:45 PM »
No..thats garbage...if you put a new sensor in, and reset your computer you will be fine, you wont notice a huge difference either way..
Getting grumpier every day.
Offline Danger-m
« Reply #2 on: July 10, 2010, 04:20:53 PM »
Thanks for the reply
I had assumed that there would be a warning light or something
I assume that the computer re-sets when the battery is disconnected?
Offline apeman
  • not as grumpy
« Reply #3 on: July 10, 2010, 04:56:30 PM »
disconnect neg batteryterminal..turn key to "on" but dont start..leave for 5 mins..turn key to off and hook up ground...restart jeep and ur done..
Offline Danger-m
« Reply #4 on: July 11, 2010, 12:03:58 PM »
Thanks, I disconnected the grn and left the key on the on position for about five min.
Everything seems good!
