Author Topic: XJ rear add-a-leaf lift  (Read 1275 times)
Offline NS-jeeper
« on: February 18, 2006, 06:36:50 PM »
I just bought a 3" lift for my xj, add-a-leaf in the rear and coils in the front (used from Jeepstuff). Some the stock rear leafs were broke but some were still good I was just wondering if when I'm putting the add-a-leaf in my spring pack if I could also put some of the extra stock leaves in from the other set as well for extra lift or would it be a waste of my time? should I just go for the add-a-leaf and blocks?
If I do put more leaves in or blocks I'll need to get a couple of coil spacers, any one know of a place to get them here in Calgary?
I know I've been a pest on the CJA site lately with all my questions but bear with me.
Scott
« Reply #1 on: February 18, 2006, 09:42:20 PM »
Adding a block to the XJ pack shortens  their life span quite dramacticaly. I had 1" lift blocks in mine and a year and a half later the main leafs had broken. Cracked across where the hole for the center pin was.
Adding leafs will give more lift but also give a stiffer/harsher ride.
If you only want a bit more lift shackles would be the way to go.
Modern and National 4WD here in Calgary would both sell spacers and shackles.
I have gotton some excellent pricing from North Shore Offroad as well.
http://www.NSOR.com
