Author Topic: JK dana 30 carrier and spider gears needed ASAP  (Read 2006 times)
« on: August 06, 2010, 03:47:50 AM »
ok so heres the short story
friend of mine has a JK on 35's and well he was wheeling and suddenly he hears a noise
so he stops    noise goes away    he drives noise comes back
he calls me up .. i go look at it and well i pull the front cover off and he exploded the carrier and the spider gears are just a mess
so question now is
is a dana 30 a dana 30     meaning dana 30 from a jk the same as any other dana 30 from a tj / xj / mj / zj
if so does anyone have one laying around for cheap
ring gear and pinion gear seem to be fine  just need the carrier and the spider gears
thanks
Re: JK dana 30 carrier and spider gears needed ASAP
« Reply #1 on: August 06, 2010, 08:16:31 AM »
I don't know that a 30 is a 30 is a 30.
I think that the JK Dana 30 has a couple things that might be different - ABS tone rings? A different (encapsulated) unit bearing? Then again, you're only looking for the carrier and the spider gears, so you might be okay.
I'm not saying that you can't find a way to make a take-off work, just suggesting that it might be a bit more difficult than putting a TJ axle on an XJ.
Here's one other thing...he's already proven that he can do some pretty good damage to the Dana 30 on his 35's - maybe it's time to get a 44 under there? You can buy Dana44's that are bolt-on for a JK. Currie makes some VERY nice stuff - and they adress the biggest issue with the stock front JK Dana 44, which is the relatively small diameter tubes and the weak C's. I'd say look for a JK Dana 44 take-off, but nobody around here seems to be upgrading their JK front axles.
« Reply #2 on: August 06, 2010, 09:22:43 AM »
i agree on that .. only problem is that its a lease and it goes back in a few months so  hes just looking to put in a new carrier and remove the lift and back she goes and then he's prbably getting a rubicon
i know the jk has the abs and all other stuff evening being a bit wider .. but i dont know if the carrrier is differnet and thats what i need to find out
Offline Pookapotamus
« Reply #3 on: August 06, 2010, 09:35:01 AM »
I still have my complete carrier from my dana 30, its out of a 92 xj. you can have them for free so if they dont work your out nothing.
Pook
« Reply #4 on: August 06, 2010, 11:29:16 AM »
It depends on the carrier break Jeff, but I have a lot of d30 carriers. Probably a dozen or so 355 an under, and a couple 373 and up.
« Reply #5 on: August 06, 2010, 11:41:06 AM »
he says he has 4.10's in it
i thought the carrier and spider gears are all the same     isnt it the ring gear and pinion where your reduction is
his ring gear is ok . and isnt chipped at all
« Reply #6 on: August 06, 2010, 11:50:58 AM »
if he has 4.10"s mine will not work for you, the carriers are offset to accept the bigger ring gear with a 4.10. my spiders might still work but not sure.
« Reply #7 on: August 06, 2010, 12:16:57 PM »
oh ok .. well thats shity   now i have to find something thats near imposible
any one got a dana 30 carrier that will accept 4.10 gears   with spider gears in it as well
thanks
« Reply #8 on: August 06, 2010, 12:21:31 PM »
why wouldn't it be covered under warranty?  oh wait lift, and 35s on a stock D30......
looks like he's gonna learn a lesson the hard way...........
maybe you should just have him call stan at northridge or something Jeff, just get the new part and install em. it'll probalby be much cheaper than the 3k the dealership will cost him........
« Reply #9 on: August 06, 2010, 12:22:35 PM »
i got my d30 4.10 carrier from stan for $90!
« Reply #10 on: August 06, 2010, 12:29:59 PM »
awesome .. ill give him a call
« Reply #11 on: August 06, 2010, 12:50:34 PM »
called stan .. hes hooking me up with a carrier tomorrow   thats right on the day that they are closed :)
now i just need to confirm that the spider gears from any dana 30 carrier will work with this 4.10 set up
« Reply #12 on: August 06, 2010, 01:00:39 PM »
mine did when i went up to 4.10
