Author Topic: Lift Kit & Tire Size  (Read 4365 times)
Sleeman
« on: August 09, 2010, 03:52:53 PM »
I have a 2003 TJ....Can I run a 4.5" lift (Rubicon Express) with 35" tires?
Re: Lift Kit & Tire Size
« Reply #1 on: August 09, 2010, 05:37:31 PM »
Along with a body lift you can, I believe.  33's should be the max with 4.5 lift
« Reply #2 on: August 10, 2010, 07:10:08 AM »
Have you tried google or search the site?  This has been covered A LOT
I have seen 35s run on TJs anywhere from 0" of lift to 6" of lift.  It all depends on your creativity
« Reply #3 on: August 10, 2010, 08:25:41 AM »
sorry Scott........... i HAVE too.............
you can make anything fit ;)
« Reply #4 on: August 10, 2010, 08:38:02 AM »
You got the right idea Johnny.  That is one of the ways of being creative
Offline lizard230
« Reply #5 on: August 10, 2010, 12:04:01 PM »
i would just recommend a 1' spacer and they should run fine or just put on a 33' tire(saves the work)
2000 TJ
« Reply #6 on: August 11, 2010, 10:30:52 AM »
Dont put a 1" spacer with a RE 4.5 inch lift. Its already to much lift on a short arm TJ and will ride like arse. Another inch will just make it worse.
Why the RE 4.5?
Been hanging out at the local shops or something?
« Reply #7 on: August 15, 2010, 10:09:10 AM »
Now if by spacer you mean body lift then you're on the right track. I'd wait and see which tires you want to run, what width of rim, how much backspace etc. I've seen 35s run on 3" suspension lifts only. There are way too many variables to say oh you need exactly X amount of lift for this size tire. Hell even the shape of the tire itself will change everything.
« Reply #8 on: August 16, 2010, 07:15:28 AM »
Correct me if I am wrong, but I was always under the impression that tires were circular in shape   ??? ;D
Offline apex
« Reply #9 on: August 16, 2010, 10:16:47 AM »
I shall correct you good sir!
 :D
Offline Pookapotamus
« Reply #10 on: August 16, 2010, 10:30:12 AM »
don't those come standard on neons?
Offline Jrama
« Reply #11 on: August 16, 2010, 10:50:45 AM »
should be fine.  they say 4" lift and a 1" BL will clear 35's Plus I hear the re 4.5 gives a little more lift then promised
« Reply #12 on: August 16, 2010, 12:22:35 PM »
 :D
Does Interco know that you've posted a pic of their tire on this site?
