Author Topic: Rear flex line on a yj  (Read 715 times)
Offline Tyler
« on: August 15, 2010, 11:56:33 PM »
I need to replace the flex line that runs from my frame to the axle.I can't figure out how to remove the hose from the junction box on the axle. Any help would be great thanks Tyler
Re: Rear flex line on a yj
« Reply #1 on: August 16, 2010, 08:31:49 PM »
im goin out on a limb here... you mean the brake hose right? if so, the junction block on the rear axle is part of the rear brake hose as well as the axle vent. remove axle vent hose, you should see the vent that comes from the axle can be unbolted. both brake lines going to the drums need to be unbolted now. letsa hope they arent too rusty. after those are removed you can unbolt the vent bolt thinger that holds the junction block to the axle. easy right :D
