Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
LCA Cam Bolt removal
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: LCA Cam Bolt removal (Read 784 times)
Evil-Jeep
UberWheeler
on:
August 16, 2010, 06:42:41 PM »
Seems like the bolt is binding inside the bushing, is there a trick I should know about to remove the bolt from the axle side of the LCA..... the nut is already off, I tried hammering and using a clamp to press the bolt out with no luck.
Logged
Evil-Jeep
UberWheeler
Re: LCA Cam Bolt removal
Reply #1 on:
August 16, 2010, 08:02:25 PM »
soaked in penetrate, swore at it, wrenched it the opposite direction and broke it loose..... came out super easy after that.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
