Author Topic: Clunking noise when I slow down when in second or low gears  (Read 1446 times)
cdlees
« on: August 16, 2010, 09:30:00 PM »
I am experiencing a clunking noise, maybe from the tansmission or engine area when I slow down and I am in either second or first gear. I seems to be only when I am slowing down and not at high speed in higher gears. Has anyone experienced this before of any ideas what it may be? Thanks
Re: Clunking noise when I slow down when in second or low gears
« Reply #1 on: August 18, 2010, 05:33:18 PM »
Is the noise at wheel speed or faster at drive shaft speed...?
I think it's a u-joint somewhere in your drive train...
Offline BrokenAxle
    • Broken Axle home page
« Reply #2 on: August 18, 2010, 08:09:21 PM »
I would be inclined to agree with Dom...
« Reply #3 on: August 18, 2010, 08:17:50 PM »
Does it clunk only at low gears, or does it clunk when moving between gears at low speeds?
x3 on the u-joint
cdlees
« Reply #4 on: August 24, 2010, 08:46:08 AM »
The more I hear it, the more I think it sounds more like a low speed vibration sound like something is loose and vibrates at low speed/higher revs????
« Reply #5 on: August 24, 2010, 10:46:15 PM »
How many km on your beast? Does it do it in 4wd or just 2wd?
cdlees
« Reply #6 on: August 26, 2010, 09:40:15 PM »
my jeep has 250,000 but it only seems to do it in 2wd and at lowers speeds, it almost sounds like something is loose!! Anyone anyadvice or suggestions?
« Reply #7 on: August 26, 2010, 10:28:14 PM »
It's hard to diagnose a vehicular malady online. The most people can do for you is throw out suggestions.
I'm leaning towards a driveshaft u-joint as I've had the same problems as you in the past(common Jeep problem)
Your best bet is to have a friend who is mechanically inclined have a look  at your Jeep or take it to a shop.
cdlees
« Reply #8 on: August 30, 2010, 08:57:48 AM »
are driveshaft u-joint gnerally expensive to replace???
« Reply #9 on: August 30, 2010, 10:13:26 PM »
No.
