Author Topic: Wanting a cheap lift for a 1993 YJ  (Read 1616 times)
cdlees
« on: August 16, 2010, 09:34:12 PM »
I am wanting a cheap lift either a 3" or 4" for a 1993 jeep YJ that I recently purchased. The Jeep has had its struts and shocks replaced last year so I am hesitant to have them a lift installed with shocks. Does anyone know of a cheaper way to install a lift? If so what would they be and where installs them?
Re: Wanting a cheap lift for a 1993 YJ
« Reply #1 on: August 16, 2010, 10:02:56 PM »
your jeep doesn't have struts ;)  its leafs and shocks.
if you are bent on keeping the stock suspension stuff you could just do a 2" or 3" body lift. but body lifts suck.
if you opt for a suspension lift, you will have to go with longer shocks otherwise you will bottom out your stock ones and wreck them.  it is fairly easy to lift a YJ.  but, shocks will be needed with just about every option.
you can go spring over axle (google it ;) ) and that'd net you 6" or so. but will give you drivelline headaches. you can also go more modest, with a 2" by extending your shackles.  or you can go with 2.5" or 4" springs which is a very good option as well.
modern or national can install the lift for you but you will pay top dollar.........
« Reply #2 on: August 17, 2010, 06:10:02 PM »
why do yuo want to lift it? what size tires you looking for? cheap doesnt apply very well.
Offline BrokenAxle
    • Broken Axle home page
« Reply #3 on: August 18, 2010, 08:03:37 PM »
Give us a call at the shop and we can get you a quote done up, both on the lift and an install.  We will match or beat any quote from a competing shop.
Dave
403-237-7706 (you can talk to Rachelle too!)
« Reply #4 on: August 18, 2010, 09:17:34 PM »
That is the better option!!!
LOL!!!!
