Author Topic: Flasher Keeps blowing....  (Read 2036 times)
Offline thayer03
« on: August 28, 2010, 03:59:42 PM »
So the Comanche had no turn signals when I bought it. Changed the flasher and all was good for a day or two. Blew again so I changed it again and this one worked for 2 blinks and died as well. Where do I look next ya figure?
Randy
FSJ's RULE!!!
Offline AV.NINE
Re: Flasher Keeps blowing....
« Reply #1 on: August 28, 2010, 04:51:49 PM »
Randy
Somewhere in the system has a power wire that is being grounded out. Does it blow with a particular side on? (left or right?)
Offline thayer03
« Reply #2 on: August 28, 2010, 05:19:47 PM »
Honestly did not pay attention. I will replace it again and try to pay attention to what wide it blows with. I should also mention 4 way flashers work just fine.
FSJ's RULE!!!
Offline AV.NINE
« Reply #3 on: August 28, 2010, 05:47:59 PM »
Then I would have to say that your signal light switch is gone. Just an educated guess though. Maybe one of the other professionals can wager a guess but by order of elimination in my mind of grounds/power wires, sounds like the case to me.
Just a thought too, you positive its the right amped fuse and flasher? I couldn't put my finger on why the fuse wouldnt be blowing and the flasher would, but I would check fuse amp first. Previous owner could have had the fuse blow and blow and blow then just stuck like a 30 in there.... now the flashers blowing.
« Last Edit: August 28, 2010, 05:51:08 PM by AV.NINE »
