Author Topic: axle help  (Read 2047 times)
Offline nobody
axle help
« on: September 01, 2010, 07:20:58 PM »
Can I take the axles out of the front of my 1994 yj to change the u-joints and still drive to work and back with-out them in there ???
Re: axle help
« Reply #1 on: September 01, 2010, 07:38:12 PM »
no. wheel bearings wont be happy.
Offline fug
  • Airdrie Pick n Pull
Re: axle help
« Reply #2 on: September 02, 2010, 12:14:59 PM »
and by unhappy wheel bearings we mean the wheels will come off.
Fug
TJ Rubicon
Offline rws
  • Stump Grinder
Re: axle help
« Reply #3 on: September 03, 2010, 08:13:19 AM »
NO
Offline dontask
Re: axle help
« Reply #4 on: September 04, 2010, 12:28:02 PM »
wont you leak lots of oil as well?
Re: axle help
« Reply #5 on: September 08, 2010, 09:37:30 PM »
maybe some oil, but you wouldnt notice when the wheel fell off at speed. i can get pics from an old friend that had this happen.
Re: axle help
« Reply #6 on: September 09, 2010, 05:15:23 PM »
you can if you take apart your axle shafts and replace your outer ( the stubby outside ends)  they hold your unit bearing together .. so if there not in then your unit bearing will come apart and youll loose your wheel and ripp out you break lines
very messy
Offline 2grand4u
Re: axle help
« Reply #7 on: September 09, 2010, 07:58:08 PM »
use a grade 8, 3/4 or 1 inch bolt with some washers tighten the squirt out of it, and if you want the oil to stay in put some tennis beans in the tube, they fit perfect.
Ryan
PS i wouldn't hit the highway or deer foot like that but it will get you bye
Offline jpthing
  • I like things with wheels.
Re: axle help
« Reply #8 on: September 09, 2010, 09:49:39 PM »
Ryan
I don't know about this idea...
If you want to drive w/o front axle shafts, just get a second  set from the wreckers and install just the stub axle (short outer part) that is all you need to keep the bearing from seperating...and as far as the oil goes, this may sound crazy, but you could "drain" it...It's this weird thing you're supposed to do anyway once and a while...oh yeah a refilling it after couldn't hurt either.
'10 JK unlimited
-Henry Ford
Re: axle help
« Reply #9 on: September 09, 2010, 10:18:47 PM »
i'm gonna jump in here and help you out before someone flames you;
with the shafts out and the stubs in, (and the vehicle in 2wd) the front diff won't spin. i'd take the DS off for pewps and giggles. that is, as long as you have somewhere to drain it
