Author Topic: I scooped up a sweet deal  (Read 1940 times)
Offline esi
« on: September 12, 2010, 11:49:21 PM »
I picked up another jeep today.
2001 WJ limited, loaded
98K
$7500
Anyone out there that has one; are there any common issues with them besides the mixer door and to nake sure the oil is changed extra regularly?
Thanks Dale
Formerly of Boots & Boost Inc
Re: I scooped up a sweet deal
« Reply #1 on: September 13, 2010, 08:35:01 AM »
what engine dale?
brakes on these were all garbage.... warped rotors, etc. bad from the factory and there was a recall (done by 36k miles though, so you can't get it done.... )
transmissions (V8) all had electrical problems; usually 'speed sensors'  actually its very easy to fix; but they are dealer-only parts.
change the tcase fluid if its AWD. again, dealer only fluids for the 247.
i also needed exhaust and some other little knickknacks.
overall good vehicles!
check this website out www.wjjeeps.com
tonnes of info on these guys
Offline esi
« Reply #2 on: September 13, 2010, 09:53:15 AM »
Its got a 4.7. Thanks for the link.
It will get handed off to me after the wife uses it for a while.
Offline corsjeep
« Reply #3 on: September 13, 2010, 07:14:32 PM »
You mentioned the oil changes~ do these motors have that same sludge up problem that the 2.7 chrysler engine has? I was allways wondering if the 4.7 was a decent engine, i hear they have manifold issues but never heard much else about them, good or bad.
