Author Topic: whats the biggest tire you can put on stock 98 tj  (Read 3653 times)
scottiesjeep
« on: September 23, 2010, 07:31:24 PM »
there is 31 10.5 15 on there now can i go bigger and wider on those rims
thanks
Offline lizard230
Re: whats the biggest tire you can put on stock 98 tj
« Reply #1 on: September 23, 2010, 07:58:55 PM »
you can go up to a 35 stock
but if u dont wanna cut your fenders 31 10.5 will rub but there the biggest you would want to go
2000 TJ
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #2 on: September 23, 2010, 11:13:26 PM »
I fit 33X12.50's with no rubbing on my gf's 97 with a 2" spacer lift. Had 15X8 wheels with 3.75" backspace though.
84 Mustang GT-Built 351W 5spd
Offline Zombie
  • Jeff the Zombie Jeep
« Reply #3 on: September 23, 2010, 11:14:54 PM »
if it one of the ones with smaller tires to start with, like a 205/75r15, the 30x9.5r15's will still rub a little without adjusting steering stops, not to mention the flex.
I tried at work a few weeks ago without luck. that was with the stock 15x7's steelies, with the right offset of wheels, a a little lift, 31's are easy
« Reply #4 on: September 24, 2010, 11:06:12 AM »
i wheeled with a guy that runs 33x12.50 Boggers on completely stock TJ. He removes the fender flares to wheel.
On road, it rubs at full turn if going over curb.
Offline parabs
« Reply #5 on: September 28, 2010, 10:03:21 PM »
a 98 tj came with an assortment of rims, but if you are running 31x10.5's I would bet that you have the 15x8 "gamblers" on it.
conventional thinking is that is the largest size you can go, everything else being stock.  Like other posters say, trim/remove/change the flares and the wheel offset and you could run a larger tire.
I have 32x11.5's on a stock suspension, with bushwacker "flat urethane" flares and mickey thompson 15x10 classic II's.  No rubbing, and I could fit a 33x12.5 and maybe even a 33x13.5 on it...
2000 TJ Sahara - Sold
Offline Strongbad
« Reply #6 on: September 29, 2010, 10:24:26 AM »
I have a basically stock 97 TJ Sahara, and I have run 33x12.5x15's on it for the last couple years.
the only thing I put on it was a 2" budget boost (those urathene coil spacers) and washers in the steering stops.
(as the tires will run on the sway bar at full lock on the steering wheel.)
the rims I have are 15x8 Jeep "Gambler" rims.  (if you need a set, I happen to have an extra 5 rims laying around)
Enjoy !
Offline mikehager52
« Reply #8 on: October 07, 2010, 10:16:36 AM »
I also have a stock '98 TJ with the 15" steelies, I recently purchased a used set of Gambler rims and am also looking to put new rubber on them without doing any mods/spacers or lift. anyone have any ideas as far as just a nice general tire size to put on them ie: 245-75-15?? Thanks for the posts.
'98 Stock TJ
Offline parabs
« Reply #9 on: October 07, 2010, 10:23:23 AM »
31x10.5x15.
Best/biggest tire size you want to run on an otherwise stock tj running gamblers, IMHO
