Author Topic: diff help  (Read 1155 times)
Offline nobody
diff help
« on: October 04, 2010, 06:04:47 PM »
Are the pinion bearings hard to change in a 95 yj
Re: diff help
« Reply #1 on: October 04, 2010, 08:02:43 PM »
Uhh what was wrong with the answer in here?
http://forum.calgaryjeep.com/index.php?topic=20060.0
Offline nobody
Re: diff help
« Reply #2 on: October 04, 2010, 08:59:35 PM »
no that was all good sorry bout that one..........what I was wanting to ask after i take drive shaft off then the yoke nut can the bearing be taken out or does a guy need to pull axles
Re: diff help
« Reply #3 on: October 04, 2010, 09:05:05 PM »
you need to pull the axles and the innards of the pumpkin then brass punch/hammer out the old races, brass punch/tap in new ones.  this may affect preload.  some diffs use crush sleeves so lots of torque required.  also need new pinion nut and seal.  it isn't a lot of work if you have the tools and done it before.  if not, can take a good amount of time.
Offline nobody
Re: diff help
« Reply #4 on: October 04, 2010, 09:11:56 PM »
well if I have it all apart maybe i will put in a posi thanks for your help pal how does one become a member of this club I mean more then on here and where does one pay his dues?
Re: diff help
« Reply #5 on: October 04, 2010, 09:14:05 PM »
