Author Topic: possible diff swap  (Read 1047 times)
Offline nobody
possible diff swap
« on: October 04, 2010, 10:12:11 PM »
what diffs would be a good swap for yj diffs?
Offline Tyn Pow
Re: possible diff swap
« Reply #1 on: October 05, 2010, 11:41:58 AM »
D30/35
60's
Hi9's
Rockwells
 ;D
What size tires do you have?  Stock engine?  Do you wheel or daily drive?  What are your plans for your rig?  Do you have tools?  Can you fab?
Based on your previous posts your best swap is probably just straight replacements with better condition axles.  Decent D30/35's can be found everywhere for cheap.  Kijiji and PNP are your friends.
Offline nobody
« Reply #2 on: October 05, 2010, 10:16:17 PM »
well I want to do both wheel and daily drive but plans this winter are small block chev and tranny and t/c out of a 1977 blazer engine trans and t/c are all rebuilt just wondering if I could even use the diffs out of it they are 4;56 gears and a set of 39.5 super swampers are coming from ON with a friend so I will be busy
Offline rangerdanger
« Reply #3 on: October 06, 2010, 08:11:45 AM »
The full size stuff will work but you will have to fabricate/have a shop do a couple things for you such as fabricate  safe crossover steering, and outboard the spring hangers in the front, will also need new driveshafts and mounts for the drivetrain. Be prepared to spend some $$$$
Lethbridge Coulee Kruzer
