Author Topic: WJ Dual Climate Problem  (Read 1114 times)
Offline AV.NINE
« on: October 13, 2010, 10:08:42 PM »
I have read on all the other jeep sites about this, the dual zone blend door brakes and basically driver gets hot air passenger gets a/c.
I have ordered the repair kit for this, does any one have experience with changing one of these??
I read there's 2 ways, the 12 hour way and the 30 minute way...
Re: WJ Dual Climate Problem
« Reply #1 on: October 14, 2010, 12:03:47 AM »
Are you talking about the " Heatertreater " kit ?
A member named " DAC " had the same problem with his WJ last year. He went with the Heatertreater kit and things worked well for him. He said it was a PITA to do with all the contortionist positions he had to do to install it. Do yourself a favour and limber-up before you do this fix. IIRC the dealership charges close to $1200 to fix this problem. It's not a fun job to fix the malfunctioning blend doors but you'll save yourself a lot of money.
Remember Justin....stretch!
« Last Edit: October 14, 2010, 12:32:27 AM by tubby »
Offline AV.NINE
« Reply #2 on: October 14, 2010, 05:14:15 AM »
Ugh....not looking forward to this one. Will send dac a pm.
Offline dukabor
« Reply #3 on: October 21, 2010, 04:56:59 PM »
I have done this on my WJ..... there is a cheap and simple way to do this as well..... if you want any details, let me know.....
« Reply #4 on: October 21, 2010, 04:57:48 PM »
Do tell dukabor
Offline AV.NINE
« Reply #5 on: October 21, 2010, 06:53:49 PM »
Yes please tell!
Offline dukabor
« Reply #6 on: October 23, 2010, 01:19:11 PM »
Easy to see as a visual, but I cut into the box with a dremel, and eith left the door closed or open (depending on the time of year heat/cold), when the weather turns cold in the fall/winter, I flip the position of the door and I get heat, when it warms up in the spring, I change it again and I get the A/C.... once you perform the mod once, it takes about 10 minutes to do it again with a screwdriver and some metal tape.... I posted a write up on wjjeeps.com, or maybe ju a while back I will try to find it, but it may be easy for anyone who wants to see it to just make arrangements for that and you can take a look....
I wasnt going to spend the big $$ for the dealer repair, or even the heater treater..... my plan was to eventually just attach the 2 doors together, but this is so quick and easy I haven;t bothered....
found a thread on it.... there are pics too.... my cuts were alot cleaner though...
http://www.jeepforum.com/forum/f13/temp-blend-door-fix-could-work-671134/
« Last Edit: October 23, 2010, 01:23:25 PM by dukabor »
