Author Topic: Removing Driveshafts  (Read 904 times)
Offline Knox
« on: October 15, 2010, 06:21:16 PM »
Removing the Driveshafts
so I've removed the 4 - 5/16 screws adn the little bridges but whats the trick to getting it uncoupled?
Do i just need to stop being a pussy and give it a good wack?
Also will the front driveshaft behave the same way? (ie unattach the front then pull it out of the tranny?
2003 TJ
Offline raf2379
Re: Removing Driveshafts
« Reply #1 on: October 15, 2010, 06:25:33 PM »
just use a prybar to pry it loose, it shouldnt take much force to pry the joint.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #2 on: October 15, 2010, 08:33:05 PM »
The front shaft has 4 x 8mm bolts at the transfercase end as well
98 TJ 4" lift + goodies
Offline Tyn Pow
« Reply #3 on: October 15, 2010, 09:41:43 PM »
Yes, but not directly on the hollow shaft as you could dent it.  Pry bar would be best as already mentioned.
Or you could go for a short drive, that should seperate it for you. :P
(just kidding!!)
Offline Knox
« Reply #4 on: October 15, 2010, 11:01:49 PM »
ha yeah I picked up a prybar tonight, gonna go play with it tomorrow again,
2003 TJ
Offline apeman
  • not as grumpy
« Reply #5 on: October 16, 2010, 12:26:36 AM »
just in case you didnt already...block the front and rear tires..once the driveshaft is pulled it will roll...even over you...lol
Getting grumpier every day.
