Author Topic: Removing transmission - tcase linkage issue  (Read 854 times)
Offline Knox
« on: October 16, 2010, 12:51:44 PM »
when I disconnect the t case linkage do I need to break the bushings? are they a one use type deal? I'm not seeing an easy way to disassemble this thing.
new picture in a few.
« Last Edit: October 16, 2010, 04:21:04 PM by Knox »
2003 TJ
Offline 2grand4u
Re: Removing transmission - tcase linkage issue
« Reply #1 on: October 16, 2010, 06:19:48 PM »
stick a flat blade in there and twist it will pop out of the bushing. make sense??
Offline Knox
« Reply #2 on: October 16, 2010, 08:01:43 PM »
yeah now does that break the bushing? or can I pop it back in without issue later?
2003 TJ
« Reply #3 on: October 16, 2010, 11:33:55 PM »
I put my linkage back in the old bushings no problem. Use a bit of lube and they come out/go back in a lot easier.
Offline 2grand4u
« Reply #4 on: October 17, 2010, 08:57:53 PM »
x2
