Author Topic: T-case frame insert collar nut  (Read 679 times)
Offline LLYJ
  • carport ghetto fab
« on: November 01, 2010, 09:41:42 AM »
Anyone know where I can pick up a frame insert collar nut (with the stock size thread and size) - I don't mind welding a flange on myself - I just need the part that goes inside the frame without having to make the hole bigger. (prefer not to put a bolt all the way through the frame if I can avoid it)
Thanx
05 Dodge 2500HD hauler
Offline rt01
Re: T-case frame insert collar nut
« Reply #1 on: November 01, 2010, 10:05:23 AM »
I had to go right to a Jeep dealer and order them, $16 each , part #  6035739 for the 1/2" and 6506 629aa for the 12mm
here's a link to installing them http://www.jeepforum.com/forum/showthread.php?t=390635
« Last Edit: November 01, 2010, 10:11:54 AM by rt01 »
