Author Topic: TJ rims what should I do?  (Read 6747 times)
Offline Knox
Re: TJ rims what should I do?
« Reply #30 on: November 04, 2010, 11:26:26 AM »
how did it go?
2003 TJ
Offline parabs
« Reply #31 on: November 05, 2010, 10:09:08 PM »
gonna try some of that 'goop' tonight. see if it takes the clear coat off, then spray bomb the wheels :)
how did it go, and how expensive is the goop?
2000 TJ Sahara - Sold
« Reply #32 on: November 05, 2010, 10:58:36 PM »
the goop was 9 bux.  but it didnt' do anything. note, there was no paint to strip; just the clear coat.....  i ended up sanding.  in short, they look ok.  the spare looks like crap, but meh, what can you do?  pics will come eventually ;)
Offline Zombie
  • Jeff the Zombie Jeep
« Reply #33 on: November 06, 2010, 09:11:26 AM »
I have used the aircraft paint stripper stuff in the past and it worked great on the clear coat too, took a few tries as it would make the clear really gummy and some patches did not want to come off, but it worked nicely, that and trying to sand blast them will leave them very pitted and take forever to get looking good, there are likely other forms of blasting that work well, but sand does not work well on aluminum from experience.
