Author Topic: TJ rims what should I do?  (Read 6731 times)
« on: November 02, 2010, 11:34:53 AM »
picked up these rims off Kijiji.  not sure what i want to do with them as of yet.  some of them have some clear coating issues and i'm not sure if i should paint these puppies with tremclad, or just leave them as is.
or if someone knows how to clean up the aluminum so the bad ones don't look so bad i'm listening.
what do you think?
YoungFluff03TJ
Re: TJ rims what should I do?
« Reply #1 on: November 02, 2010, 12:28:00 PM »
Neon pink. I think you should do neon pink. very manly.
« Reply #2 on: November 02, 2010, 12:47:26 PM »
Sandblast and paint em black
« Reply #3 on: November 02, 2010, 12:56:55 PM »
think a wire sheel or something would do the same??????
« Reply #4 on: November 02, 2010, 01:11:16 PM »
Probably not as cleanly as blasting them
Offline dac
« Reply #5 on: November 02, 2010, 01:25:33 PM »
A wire wheel might gouge pretty bad and it'd be awkward to get into some spaces on the wheels.  One of the fellows at the office here striped the coating off his mazda 3 wheels last fall.  Just put some sort of goop on them and it eats the coating off.  I believe it washes off after that.  Then you'd just have to buff them.  I guess it depends on how nice you want them to look.
Offline 01sahara
« Reply #6 on: November 02, 2010, 01:46:01 PM »
Sand blasting is way more fun!  ;D
« Reply #7 on: November 02, 2010, 03:58:12 PM »
how much does sand blasting cost? where'd i get it done?????????
« Reply #8 on: November 02, 2010, 04:28:05 PM »
I think Top Gun coatings can do it John. Just wire wheel it, clean it well, prime well and then paint. Its held up fine for mine.
Offline Strongbad
« Reply #9 on: November 02, 2010, 04:32:56 PM »
Yep, Top Gun Coatings has refinished Wheels for me in the past.
They do really good work. I've had things done on my Harley, and my hot rod.
Larry Carlson - 403-250-5393.
« Reply #10 on: November 02, 2010, 05:06:28 PM »
There is a do it yourself place that Ron has used.
« Reply #11 on: November 02, 2010, 05:26:29 PM »
Consolidated Compressor in the foothills area is a DIY sandblasting place. I believe they charge by the minute.
Vince
Offline esi
« Reply #12 on: November 02, 2010, 08:18:36 PM »
The goop is aircraft paint remover it eats and gells the paint, then it just washes off. Then I'd go and get some duplicolor gunmetal 0r graphite wheel paint and spray them with that.
Formerly of Boots & Boost Inc
« Reply #13 on: November 02, 2010, 08:40:37 PM »
you don't like black Dale???
« Reply #14 on: November 02, 2010, 08:49:18 PM »
gunmetal 0r graphite would look sweet. Or even chrome paint. Just be careful to not get the paint running.... it will look worse than normal paint that has runs in it.
