Author Topic: heater fan control module  (Read 1666 times)
Offline Pookapotamus
« on: November 12, 2010, 06:32:11 AM »
i have gone through 3 heater fan control modules in the last 2 months! any one else have this issue? or have any insite on how to rectify this? is there a beefed up version of this?
Pook
Offline ornamental
Re: heater fan control module
« Reply #1 on: November 12, 2010, 07:36:28 AM »
is that the resister pack your talking about?
« Reply #2 on: November 12, 2010, 08:22:01 AM »
yes  >:(
Offline BlackAura
  • 2003 TJ Rubicon (Stock)
« Reply #3 on: November 12, 2010, 12:15:14 PM »
Bad Ground?
Located in a place with lots of heat?
Do you have an old / dead module?  could try to figure out where it's failing?
BlackAura (Kevin)
« Reply #4 on: November 13, 2010, 08:17:28 AM »
When one goes the other is going as well . Change the heater fan as well . Did the same changed the resistor then two weeks later nothing , then changed both . That was three years ago
Offline Big_Jeep
« Reply #5 on: November 16, 2010, 10:52:06 PM »
Mine went tonight :o. Got in and it was working fine so I turned it off until the Heep warmed up and then nothing at all. Anyone have a good price on resistors? And should it still be working at full speed if it is the resistor? Fuses tested OK.
I was Jeepless since 2006. So I had to make a tough decision; the wife, or get a Jeep. So glad to be a Jeep owner again! I still miss my FSJ the most
« Reply #6 on: November 16, 2010, 10:54:17 PM »
Yep, and ONLY high.
Offline Big_Jeep
« Reply #7 on: November 16, 2010, 10:58:27 PM »
Fan module then?
Offline mike s
  • Good times!
« Reply #8 on: November 18, 2010, 07:05:20 PM »
The fan resistors blow because of age...or high amp draw on blower motor, if not to bad, change em as a pair.
Any news on the pook-pusher bumper project?
oldEnuff2NObetter
but still can't help myself
« Reply #9 on: November 19, 2010, 05:29:50 AM »
the first one is almost done, just waiting for more steel, come on by and check it out
« Reply #10 on: November 20, 2010, 10:30:38 AM »
As said when the fan starts to go it pulls more amps and cooks the resistor pack. Had that happen to me a couple of times.
