Author Topic: new day, new noise, new smell...  (Read 1264 times)
Offline AV.NINE
« on: December 15, 2010, 08:40:07 AM »
« Last Edit: December 15, 2010, 06:00:42 PM by AV.NINE »
Re: new day, new noise, new smell...
« Reply #1 on: December 15, 2010, 09:04:14 AM »
Turn up your stereo next time it happens  ;D
Offline NUXJR
« Reply #2 on: December 15, 2010, 09:12:11 AM »
And roll down the window to let out the smoke ::)
Offline AV.NINE
« Reply #3 on: December 15, 2010, 09:55:07 AM »
Diff fluid is fine. Possible pinion bearing? Any easy way to test that? Any other "usefull" Ideas?
Offline Pookapotamus
« Reply #4 on: December 15, 2010, 10:06:47 AM »
is it possible that you ran over a platic bag and it wrapped into some thing?
Offline Knox
« Reply #5 on: December 15, 2010, 01:42:04 PM »
lol poodle... :P
I vote bag. Any visible melted plastic on anything?
2003 TJ
« Reply #6 on: December 15, 2010, 02:46:01 PM »
You should have your muffler bearings tested too. i hear if they are worn out they’ll cause the drag on the engine which will not allow it to spin the drivebelt at the required speed.  Thus causing your alternator to act like its ‘failing’.  Theres a simple solution though; belt dressing will allow it to spin faster and make up for the worn muffler bearing.
shot in the dark, but maybe siezed parking brake? (do you use your ebrake?)  i've had it happen twice and it does stink.  i cannot remember if it made bad noises though.
if your pinion bearing were bad it wouldn't smell.....
its never just a plastic bag stuck...... that'd be to easy.
Offline AV.NINE
« Reply #7 on: December 15, 2010, 04:27:42 PM »
Actually johnny, you might be right. There's a lot less tension on it now than a month ago.
Will check it out, thanks bud.
Offline AV.NINE
« Reply #8 on: December 15, 2010, 06:00:16 PM »
