Author Topic: Screaming in 3rd, under load  (Read 1478 times)
Offline AV.NINE
« on: December 15, 2010, 05:59:25 PM »
Forget my other post, this is after more diagnostics.
The screaming sounds like a jet powering up. This is only in 3rd and only at ab0ut 2000 rpms (its non existent below that rpm and turns into a non audible high frequency above 2400ish).
Also it may be related, but when I let my clutch out at idle it makes some gawd awful noise. Once dis engaged its normal. The noise is a grinding type noise.
New clutch time?
Offline Pookapotamus
Re: Screaming in 3rd, under load
« Reply #1 on: December 15, 2010, 07:09:21 PM »
it its making noise when you are letting the clutch out then i would say release bearing so ya new clutch time.
if it is just making the noise in 3rd then you have 2 separate issues, clutch and something wrong with 3rd gear.
the burning plastic smell um... not sure.
Offline AV.NINE
« Reply #2 on: December 16, 2010, 10:00:37 PM »
Im an idiot...
Missed step 16 when I installed my short throw shifter:
STEP 16. Apply bead of silicone around perimeter of base.
Tool: RTV Silicone
Was down to 1 liter of fluid in my tranny.
Offline Knox
« Reply #3 on: December 16, 2010, 10:09:46 PM »
Hopefully no permanent damage? Glad you got it figured out.
2003 TJ
Offline AV.NINE
« Reply #4 on: December 16, 2010, 10:16:43 PM »
Seems fine, whined in every gear today, filled up tranny as soon as I could. Works normal again. Will fix Saturday.
Offline jeepjones
« Reply #5 on: December 17, 2010, 01:59:36 AM »
So you lost all the oil out of where the new shifter goes into the trans because you forgot a wee bit of silicone?
Offline AV.NINE
« Reply #6 on: December 17, 2010, 04:56:43 AM »
Yup.
Well see its a bit more complicated....
There is a stock rubber seal between the factory shifter and the tranny, rubber awkward thing. I reinstalled it with the shift which made it a pita to install. Looking at the instructions now, it appears you dont reinstall the seal and just use RTV on it.
Who knew?
Of coarse b&m dont mention anything about it. Just 1 crappy pic of the shifter half installed.
« Last Edit: December 17, 2010, 05:14:50 AM by AV.NINE »
