Author Topic: TJ Replacement headlights  (Read 1891 times)
Offline scott slade
  • Amboy... Route 66
« on: December 20, 2010, 08:29:07 AM »
Hello Gang,   Wondering if anyone has had any experience with upgraded headlights, like an hid system or just a H4 bulb and housing...?   I need to replace my headlights and thought it would be better to upgrade to something brighter and whiter....   any thoughts...  Thanks.. 8)
2005 LJ, Six Speed,
 16" Moab Rims
Re: TJ Replacement headlights
« Reply #1 on: December 20, 2010, 08:54:03 AM »
I used the Rampage houseing and bulb.  What a huge difference and it was only $100.
http://www.4wd.com/productdetails.aspx?partID=7420
I think I did order them through these guys but I'm sure you can get them a canadian source as well.
Offline scott slade
  • Amboy... Route 66
« Reply #2 on: December 20, 2010, 04:57:33 PM »
I saw those on line for about that price....  glad to see you used them.  I  noticed them on your rig last time I saw it....  I'll go with them too.  ....  Thanks....   ;D
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #3 on: December 20, 2010, 08:05:09 PM »
i used the IPF conversion lights on ym YJ, amazing how well they worked. the stock yj lights were dangerously weak. the H4 upgrade was awesome.
« Reply #4 on: December 20, 2010, 08:20:14 PM »
You should be able to find a wide variety of 7" round H4 headlights, and H4 bulbs are available in huge assortment of types and wattage. I've had great luck with the Hella lights that I put into my JK, but Cibie also makes great stuff. I haven't used IPF lights, but I've heard good things.
You might also want to look at upgrading your wiring harness. The stock wiring to your headlights is probably pretty small for the wattage...you will get more light if you run heavier gauge wires powered by a relay - you can just use your stock harness to trigger the relays. A company called Susquehanna Motorsports makes a "plug and play" harness for the JK - I am sure that someone else makes something similar for the TJ.
Offline Dagoose
« Reply #5 on: December 20, 2010, 09:02:51 PM »
I also went with the H4's and fatboy bulbs and would definitely reccomend them. I have the housing in my CJ and the stock housing in my TJ. I did a test in my garage with the two vehicles, and they housing makes the lights twice as bright. It really depends on how bright you want them.
Offline AstraX
« Reply #6 on: December 21, 2010, 12:37:09 PM »
These look pretty slick...Just don't know about dropping that kind of cash on headlights...
http://www.4wd.com/productdetails.aspx?jeep-sid=403&plID=933&partID=45063
Anyone seen or heard anything about them?
« Reply #7 on: December 21, 2010, 03:33:12 PM »
They are very cool...but don't expect first-rate performance out of them. Everything I have heard indicates that they're a top quality product...but they're built to be super durable and offer long life - not necessarily provide a ton of light.
Offline dac
« Reply #8 on: December 21, 2010, 09:20:33 PM »
Sylvania silverstars are pretty bright for about $30 a bulb.  Direct replacement.  I found mine at canadian tire.  ~4000k color temp which I believe is similar to an H3 bulb.
Offline parabs
« Reply #9 on: December 22, 2010, 12:02:25 AM »
http://www.jeepforum.com/forum/f9/h-i-d-s-my-tj-wow-842999/
I bought the same kit as the author, it is cheap, and it is chinese-made, and I wasnt expecting much, but I have had good luck with the kit so far as seen in that link above.  I know the OP of that thread has now changed his tune on VVME, but it is cheap and I wanted to see how well it would work.  I have been running mine for a year.  The pictures the OP took speak for themselves.
I bought the 4000k kit, I wasnt looking for that "hid-look", just better light.  I also disconnected the DRL, as I read that DRL's and these kits often lead to premature bulb failures.
2000 TJ Sahara - Sold
Offline fraserr7
« Reply #10 on: December 23, 2010, 08:16:32 AM »
I bught the kc highlights H4 headlights off quadratec, I like em! Way brighter then stock I find!
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #11 on: December 23, 2010, 08:22:53 AM »
I put GE Nighthawks in my gf's TJ. Lots brighter than stock. The aircraft landing lights on the bumper also help as well :)
84 Mustang GT-Built 351W 5spd
Offline scott slade
  • Amboy... Route 66
« Reply #12 on: December 23, 2010, 02:38:27 PM »
Merry Christmas to me... I ordered the Rampage lights on line,  got what I think is a good deal..... Thanks for all the advice.... ;D
2005 LJ, Six Speed,
 16" Moab Rims
