Author Topic: Electric power Question....  (Read 826 times)
Offline scott slade
  • Amboy... Route 66
« on: December 23, 2010, 02:44:23 PM »
1st Question....   one of the two power ports not working on my 05 TJ... the one closer to the driver side.  All fuses seem fine.  ??  Wires are all good.. so it seems.  2nd Question.  Where is the best spot to pull power from to add CB and or extra lights... years back I used to jump from the fuse box... is there a better spot or method to use that is safe...?   Sorry if this seems simple to some of you compared to some of the bigger tech stuff you have done...  Thanks for any help..      ::)
2005 LJ, Six Speed,
 16" Moab Rims
HD Broadcast Video Production Unit
Offline FiEND
  • Wrecking Ball
Re: Electric power Question....
« Reply #1 on: December 23, 2010, 02:51:31 PM »
best spot is always right off the battery.  if you need to run it off ignition, then you can use a relay off the fuse box for ignition sense and still have the main power from battery.  most relays are 30amp so good enough for most applications.
1Wide2High
ILV2FRT
'97 TJ [sold]
'17 JK Rubicon
