Author Topic: Rev limiter?  (Read 2319 times)
Offline Justink
  • '89 comanche 5'' lift, 33's
Rev limiter?
« on: December 28, 2010, 09:49:48 PM »
It revs up to the normal 5250 rpm when my clutch is in or it's in nuetral.  I go to hammer down in 3rd gear to pass someone and at about 3600-4000 rpm its like the rev limiter kicks in.  Any ideas? '91 cherokee 5 speed 4x4
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Re: Rev limiter?
« Reply #1 on: December 28, 2010, 09:56:23 PM »
Buckin' and jerkin' when it does this?
Offline Justink
Re: Rev limiter?
« Reply #2 on: December 28, 2010, 09:57:45 PM »
Ya thats exactly it.
Re: Rev limiter?
« Reply #3 on: December 28, 2010, 10:00:23 PM »
Throttle Position Sensor... 10 minute fix... a new one at Autovalue cost me about $50.
Offline Justink
Re: Rev limiter?
« Reply #4 on: December 28, 2010, 10:04:43 PM »
Wouldn't the throttle position sensor effect the idle to?  Sorry for the questions but only one way to learn.
Re: Rev limiter?
« Reply #5 on: December 28, 2010, 10:10:02 PM »
It didn't on mine. Hooked it up to a OBDII reader. Truck was off, and it was saying that the TPS was 30% open... just a wee bit out of whack. Mine decided to crap out on the way home from Deadmonton.... right in around 2700 rpm it would buck and dance.... that was an interesting ride when I gave it some gas to pass, or climb a hill.
Re: Rev limiter?
« Reply #6 on: December 29, 2010, 05:34:48 PM »
maybe don't have to push the throttle down as much to get the same rpm at idle.  only time mine did something like this was when my speed sensor was acting up, backed off around 3000 rpm and the speedo bounced around a little
Re: Rev limiter?
« Reply #7 on: December 29, 2010, 09:23:56 PM »
And the whole truck was bucking and bouncing?
Re: Rev limiter?
« Reply #8 on: January 03, 2011, 12:23:13 AM »
You get the problem solved Justin?
Offline Zombie
  • Jeff the Zombie Jeep
Re: Rev limiter?
« Reply #9 on: January 03, 2011, 01:26:35 AM »
I had something like that, it was only at some times though, and it may or may not drive like that, turned out I had a bad spark plug wire(the connector to the spark plug and come loose from the wire)
but ya, what the others said
Offline Justink
Re: Rev limiter?
« Reply #10 on: February 26, 2011, 04:03:47 PM »
Zombie post, but no I haven't yet.  Started driving a car instead of the jeep, nd It's to cold to be working outside right now  :-[
