Author Topic: 89 Manche,..  (Read 28032 times)
Offline JENSSEN
    • Racing For The Cure
Re: 89 Manche,..
« Reply #45 on: January 29, 2011, 09:43:34 AM »
The deck came with Fall out boy in it but the manche had a 6 disk in it with 6 great burnt CD's :)
A few updates,..
Found an AX-15 from a 99 XJ $123.00 :)
Jacked up the nose to try and figure out coils for the front,.. :o
Drivers pan came in this week,...
www.racingforthecure.ca
Offline JENSSEN
Re: 89 Manche,..
« Reply #46 on: January 30, 2011, 06:21:56 PM »
Well I plugged away and fitted the floor,... faaaawk!
Then I called the Wifey out to get some good smooth welds in on the floor
Now the new pan didn't cover 100% of the rust so I have a few more small pieces to make up,.. progress pics up soon :)
Offline Gearhead
Re: 89 Manche,..
« Reply #47 on: January 31, 2011, 07:14:05 PM »
The next time you need one of those floor pans  , let me know , I have one for the drivers side , it's been listed in my parts for sale thread for quite some time .  I have no intention of fixing up my comanche .
Offline JENSSEN
Re: 89 Manche,..
« Reply #48 on: January 31, 2011, 10:26:22 PM »
Thanks for the offer!
Updates,..
Well for the floor support I made this
upon test fitting it to the floor i decided I hated it,.... to the bin it went and made a second one, heavier gauge like stock and fit it in :)
Took about 2.5 hrs to make it and fit it,..
« Last Edit: January 31, 2011, 10:51:05 PM by JENSSEN »
Offline JENSSEN
Re: 89 Manche,..
« Reply #49 on: February 06, 2011, 06:16:50 PM »
Just got back on the rust bucket,... And made some headway !
Cab corner in :)
Rocker in/on
I am dirty and rusty,...
Offline JENSSEN
Re: 89 Manche,..
« Reply #50 on: February 13, 2011, 05:59:38 PM »
Into the windshield frame,...
Some small rust holes to be repaired,.. typical of cruddy windshield installs,..
State of the union,... and yes I know it's a mess,.. :)
Offline JENSSEN
Re: 89 Manche,..
« Reply #51 on: February 16, 2011, 09:09:51 PM »
Popped out the windshield to find this once I cleaned it up,... not acceptable!!!
So I took it out :)
and welded in some new stuff
much better :)
Now onto the next section,..
Offline JENSSEN
Re: 89 Manche,..
« Reply #52 on: February 16, 2011, 10:17:51 PM »
"A" Pillar rot now gone
Still some finishing to do but ran out of time,.. squirted it with primer to save it for later
Offline JENSSEN
Re: 89 Manche,..
« Reply #53 on: February 20, 2011, 01:09:46 PM »
Just finishing up some metal finishing in the door jams,..
Test spot on etch primer to see what it will show up for areas of improvement
some finishing on the "A" pillar,..
Offline JENSSEN
Re: 89 Manche,..
« Reply #54 on: February 21, 2011, 02:34:27 PM »
Felt a bit bogged down and a touch overwhelmed so I decided to get some instant gratification and cherry pick a few jobs on the Manche,...
Old hole for a topper I assume
and a bit of body work happened,..
Offline JENSSEN
Re: 89 Manche,..
« Reply #55 on: February 26, 2011, 05:57:14 PM »
« Last Edit: February 26, 2011, 06:03:51 PM by JENSSEN »
Offline JENSSEN
Re: 89 Manche,..
« Reply #56 on: February 27, 2011, 01:04:20 PM »
Drivers side inner and outers,..
New Cab corner
Primer slowly creeping on !!!
Offline JENSSEN
Re: 89 Manche,..
« Reply #57 on: March 01, 2011, 09:56:15 PM »
Well I needed some more instant gratification tonight so I decided to sand the roof,.. peeling clearcoat,.. seems innocent right?
first couple of passes,..
oh wait what do we have here????
FAWK more rust,...
Should of named this the "Leper" Project,..
Re: 89 Manche,..
« Reply #58 on: March 02, 2011, 09:47:49 AM »
The Leper - I love it.   Are you just using a DA for the sanding?
Offline JENSSEN
Re: 89 Manche,..
« Reply #59 on: March 02, 2011, 10:24:59 AM »
DA to knock it down then a finish sander to feather it,.. Brute force first, precision after :)
