Author Topic: no flashers  (Read 1198 times)
no flashers
« on: January 06, 2011, 06:12:55 PM »
ok so heres my new problem
i changed out my fenders to flat fenders
now wiring new flashers and corner lights and i have a problem . i lost my flasher and 4 ways
they will not work they dont even show up on the dash .. is there a relay some where i checked all the fuses and there all good the lights light up but they do not  flash
and on the dash nothing shows up
if there is a relay where would i find it
thanks
Offline Waytec
  • not all there
Re: no flashers
« Reply #1 on: January 06, 2011, 06:52:18 PM »
Are the new lights LED?
if so or not you may have to switch from a mechanical flasher relay to a electronic one. The new lights don't have enough resistance to build up heat and cause the mechanical relay to switch from side to side (flash).
The obstacle is the path.
Re: no flashers
« Reply #2 on: January 06, 2011, 08:39:09 PM »
You have to make sure you leave all the bulbs in their recepticles. Just stuff the extra ones into the grill.
Re: no flashers
« Reply #3 on: January 07, 2011, 12:20:31 AM »
ya i found that out .. but where is the relay for the flashers  its it in the fuse box under the hood or in the glove box
cuz my main issue is i think i may have shorted the wires because i had flashers earlier today but now i on my dash nothing lights up
but the lights are lit
Offline Joel
  • Super Uber Web Wheeler
Re: no flashers
« Reply #4 on: January 07, 2011, 01:50:21 AM »
On top of the steering column under the plastic cover and to the right of the hazard button.
