Author Topic: TJ Rear Recovery Hook..?  (Read 2086 times)
Offline scott slade
  • Amboy... Route 66
« on: January 07, 2011, 07:49:36 AM »
Hello,   I'm looking to add the factory rear recovery hook to my 05 TJ...  I already have a trailer hitch on the Jeep...  my question is...  would one of those "D" rings that slides into the receaver hitch work well or are they not worth the money...?    :o
2005 LJ, Six Speed,
 16" Moab Rims
Re: TJ Rear Recovery Hook..?
« Reply #1 on: January 07, 2011, 08:08:48 AM »
They work great
« Reply #2 on: January 07, 2011, 08:40:23 AM »
they work especially good pulling people uphill when they get stuck going downhill  ??? ??? 8) 8)
Offline scott slade
  • Amboy... Route 66
« Reply #3 on: January 07, 2011, 08:48:59 AM »
is that the voice of experiance talking...!!!!!!    :)
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #4 on: January 07, 2011, 08:49:33 AM »
Why do you have to say such things Johnny...  Seriouly, I mean, seriously...
« Reply #5 on: January 07, 2011, 08:54:33 AM »
its ok Kev, i got stuck in a parking lot last week....... :'(  granded i had no front driveshaft in the jeep never the less.....
check out this, i've got one, and lord knows its stood up to some hard pulls on my YJ
http://warn.iwebcat.com/_Members/lookups/partdetail.asp
« Reply #6 on: January 07, 2011, 11:16:34 AM »
Just remember, that design was built to tow a trailer.
With tires, on road... Very little resistance (Compared to pulling on dead weight Jeep with another Jeep)
In the right (or should say wrong) circumstances, they will fail. Keep that in mind when you are staring at the 10Lbs of steel attached to thousands of pounds elastic band of a strap aimed directly at you, pulling out the receiver hitch equipped Jeep in front of you...  ;D
Once again, the yearly reminder picture. (Receiver ended up in the back seat)
And for good measures... Bent up stock hook on one side, ripped frame on the other... Be careful !
« Last Edit: January 07, 2011, 11:20:56 AM by frenchy »
« Reply #7 on: January 07, 2011, 02:49:00 PM »
Ive pulled people out on a 1 inch receiver and hard it never let me down
I've pulled 4 door diesels out of mud holes and that was with 20 foot running start
My hitch never moved or bent and it sure as hell never ripped off and hit a truck
But I guess crap happens
Offline Slewfoot
« Reply #8 on: January 07, 2011, 03:57:12 PM »
Did the receiver break away from the rest of the hitch assembly?  Or was it the shackle and holder that flew because the pin broke?
« Reply #9 on: January 07, 2011, 09:37:52 PM »
Was the pin, sent the receiver flying...
I've also heard of the trailer hitch assembly breaking. It eventually will when put up to the abuse of 20 Ft running starts pulling 7000Lb immovable objects  ;D  They rust and are never maintained, just abused.
If you have to use a trailer hitch for recovery I would almost say feed a strap to the pin instead of inserting a big heavy steel projectile in the midle.
