Author Topic: Re-Gearing a D44  (Read 2031 times)
Offline WagoneerXJ
  • Bagon Wagon!
Re-Gearing a D44
« on: January 10, 2011, 04:47:07 PM »
I've got myself an XJ Dana 44 that was from a 4.0 5spd jeep. Pretty sure it's got 3.07's in it. Assuming that it does, would i need a new carrier to go with 4.10's?
84 Mustang GT-Built 351W 5spd
Re: Re-Gearing a D44
« Reply #1 on: January 10, 2011, 04:48:35 PM »
yep..... 3.73 and up I beleive.
« Reply #2 on: January 10, 2011, 04:51:35 PM »
did i read somewhere that you can use that 307 carrier with thicker gears or am i sniffing Dom's crack again?
or is it just for rubi 44's?
« Reply #3 on: January 11, 2011, 07:53:35 AM »
You could use a thick gear set, or rubicon gear set (which is thick). Rubicon lockers are 373 and down offset, but the gears are 410. So, to compensate for the difference, the factory installed thick gear sets into rubi 44's.
Only difference is that the rubi gear uses a larger bolt, meaning a standard carrier would need to have the bolt holes drilled from 3/8 - 7/16 in order to use a rubi gear set.
I just wrote this last week for Aron. Pay attention Al ;)
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #4 on: January 11, 2011, 08:00:33 AM »
That's what I thought. Can you buy a new carrier? or is it time to hit the junkyards? Would TJ D44 parts work, or Rubicon? I don't want a locker, just the 4.10's.
« Reply #5 on: January 11, 2011, 11:23:59 AM »
You can get a non loaded carrier from northridge for about 80 bucks.
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #6 on: January 11, 2011, 01:26:00 PM »
Awesome. Much cheaper than I thought. Makes goin to a junkyard not even worth my time! Thanks  Bnine!
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #7 on: January 11, 2011, 04:02:18 PM »
I couldn't find any carriers on their site???
« Reply #8 on: January 11, 2011, 04:10:45 PM »
Just call stan. I've gotten dozens of them off Northridge over the years. Gears are kind of my thing.
Offline apeman
  • not as grumpy
« Reply #9 on: January 11, 2011, 04:12:32 PM »
I just happen to have a spare set of rubicon d44 4.10 gears you can have..
Getting grumpier every day.
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #10 on: January 12, 2011, 02:40:43 PM »
Done! PM'd
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #11 on: January 12, 2011, 02:42:08 PM »
So that's all there is to it, to re-use my carrier? Sounds too simple!
