Author Topic: AIR PUMP  (Read 4788 times)
Offline THE GOLD DIIGGER
AIR PUMP
« on: January 30, 2011, 09:50:57 PM »
WHERE DO I GET ON BOARD AIR PUMP
Offline silverfox
  • drawrof og nac enoyna
Re: AIR PUMP
« Reply #1 on: January 30, 2011, 10:22:42 PM »
FROM NORTHRIDGE 4X4!!!
 :o
2018 JLU Lifted on 37's
Offline Slewfoot
Re: AIR PUMP
« Reply #2 on: January 30, 2011, 10:49:52 PM »
I have this:
ARB Air Compressor for Air Locker & Tire Inflation
and this:
ARB Air Compressor Pump Kit
Quite happy with both, though I did pick up a longer hose from Princess Auto (supposed to be good to -40 deg C).
Offline silverfox
Re: AIR PUMP
« Reply #3 on: January 30, 2011, 10:52:25 PM »
I have this:
and this:
Yup and Stan has a custom bracket that mounts to the bolts of your master cylinder for a great mounting platform for the ARB
Offline Slewfoot
Re: AIR PUMP
« Reply #4 on: January 30, 2011, 10:57:21 PM »
I thought those mounting brackets for the master cylinder were for JK's only - do they have one for TJs?
Offline silverfox
Re: AIR PUMP
« Reply #5 on: January 30, 2011, 11:01:33 PM »
Dunno but the OP is running a JK if I recall correctly
Offline ornamental
Re: AIR PUMP
« Reply #6 on: January 30, 2011, 11:15:38 PM »
Offline Slewfoot
Re: AIR PUMP
« Reply #7 on: January 30, 2011, 11:23:43 PM »
OP is Bryan, running a Gold TJ Rubicon with swampers and chains :)
Offline silverfox
Re: AIR PUMP
« Reply #8 on: January 30, 2011, 11:27:08 PM »
My bad I thought it was a JK
In the case of the TJ I think you can mount it directly on the drivers side fender well ( heavy on the I think part) as there is a nice open space for it there.
Offline BrokenAxle
    • Broken Axle home page
Re: AIR PUMP
« Reply #9 on: January 31, 2011, 07:43:35 AM »
I would second the viair setup!
Re: AIR PUMP
« Reply #10 on: January 31, 2011, 08:13:12 AM »
So you're saying he'll want to mount it the same way that you did?
Offline 78ram
Re: AIR PUMP
« Reply #11 on: January 31, 2011, 10:11:05 AM »
i got a brand new viar 380 C chrome compressor sitting in my garage that i'm not needing $200 firm it's not in the box anymore but regardless it's still new
Offline Slewfoot
Re: AIR PUMP
« Reply #12 on: January 31, 2011, 10:23:11 AM »
Nope - I'm just saying that Bryan drives a TJ  :P
But, since you brought it up  ;D, I mounted mine on the driver's side fender (as was mentioned before).  It's convenient there, and seems to be out of the way.  If I had to do it again, I'd really consider seeing if someone could fab up a bracket and mount it off the firewall, or some other place under the hood (quite honestly, if I'd have found a bracket available for TJs that would mount to the brake master cylinder/booster like the JK bracket mentioned, I'd have used it).
Offline AstraX
Re: AIR PUMP
« Reply #13 on: January 31, 2011, 10:58:41 AM »
Just ordered up an ARB today!  Call Stan at Northridge, he has them in stock...ordered it today, he said I will have it tomorrow.
The bracket for JK's are pretty slick, I am surprised there isn't something similar out there for the TJ...
Re: AIR PUMP
« Reply #14 on: February 01, 2011, 11:07:35 AM »
WHY DO YOU GUYS REPLY TO RETARDED QUESTIONS WITH COHERENT ANSWERS?
Are you really so eager to share a bit of tech and or info that you will do so when the person asking shows no respect what so ever for common board etiquette?
