Author Topic: 99 TJ Tranny  (Read 1221 times)
Offline birdo
  • 99 TJ
99 TJ Tranny
« on: February 17, 2011, 09:53:25 PM »
Hi All,
Just purchased a 99 TJ a couple of weeks ago.
The 5-speed manual transmission is thick as molasses on these cold days and shifting requires some doing.
Once it warms up its a bit better.
I would like to change out the gear oil to something a bit less viscous. Any suggestions? It's an AX-15 tranny.
Probably would like to go synthetic.
Cheers
John in Okotoks
John Bird
Okotoks Alberta
1999 Jeep TJ Sahara
Desert Sand
Some Cheapo Clarion Stereo
Heated Seats, Air-Con, Cruise
230,000 kms
Offline AMCJeep
Re: 99 TJ Tranny
« Reply #1 on: February 18, 2011, 06:17:02 AM »
I use Royal Purple Synchromax in mine.
It shifts like butter even with these cold temperatures.
You can get it at Mopac.
03 Ram 2500 QC, LB, 5.9 CTD
Re: 99 TJ Tranny
« Reply #2 on: February 18, 2011, 12:28:04 PM »
Redline MT90!
Expensive though.
Try popping the bottom of your shift boot up out of the center console 9/10 shifting problems is that stupid boot not the tranny itself.
Offline birdo
  • 99 TJ
Re: 99 TJ Tranny
« Reply #3 on: February 18, 2011, 09:14:35 PM »
Yeah.....was considering the rubber boot thing. That rubber sure stiffens up in the cold.
I'm not sure what's in the gear box now but when it hit minus 30 a while back, it is pretty hard to
move the shifter anywhere....
John Bird
Okotoks Alberta
1999 Jeep TJ Sahara
Desert Sand
230,000 kms
Re: 99 TJ Tranny
« Reply #4 on: February 19, 2011, 06:38:13 AM »
Pull the plastic boot retaining trim piece and let it "float".
Also, when you run the engine to warm it up, put the t-case in neutral and shift the tranny in 2nd or 3rd gear and let the clutch out while warming up. It really makes a big difference in warming up the tranny fluid and it will shift much, much easier.
Vince
Offline birdo
  • 99 TJ
Re: 99 TJ Tranny
« Reply #5 on: February 19, 2011, 12:37:41 PM »
Thanks Vince,
I did that this morning and it does work. Thanks for the tip.
John Bird
Okotoks Alberta
1999 Jeep TJ Sahara
Desert Sand
230,000 kms
