Author Topic: where can you buy a 1.5" 7.15 degree reamer in Calgary?  (Read 2485 times)
« on: February 18, 2011, 04:07:03 PM »
to ream out my knucles or OTK steering?  or should i just order it online and wait?
cheers
Offline yyc_tbird_sc
Re: where can you buy a 1.5" 7.15 degree reamer in Calgary?
« Reply #1 on: February 18, 2011, 05:29:11 PM »
Check with guys at ACT tooling....the last time I talked with them about reams and taps for my solid axle swap project they said if they didn't have it, they'd get it.
Offline JeEpGrAnD
« Reply #2 on: February 18, 2011, 06:28:32 PM »
You can call thomas skinner they deal with machining inserts and tooling they will be able to get one :)
Offline fug
  • Airdrie Pick n Pull
« Reply #3 on: February 18, 2011, 06:32:51 PM »
Is that the standard taper used to do the 1 ton stuff?  I have one kicking around that should be good still.  Do yourself a favor... and get someone with a really good drill press to do the reaming.  The reamers are brutally expensive (I think I paid better than $100 for one) and if you can't hold them really still you will dull them in about 2 mins.
Fug
TJ Rubicon
