Author Topic: Yet another track bar question! XJ  (Read 1937 times)
Offline halfcRoOk
« on: February 19, 2011, 12:55:18 AM »
So I just finished putting in my front coil spring spacers, and while I was putting everything back on, getting ready for an alignment, I couldn't get the track bar in, guessing because of the lift, could it be that my axel is just shifted, or would I need to either try n center it then drill a hole or wait till I can get an adjustable track bar?
1991 Cherokee 4x4
1988 Cherokee 4x4
1978 Austin Mini 1000
Also looking for a Comanche!
Re: Yet another track bar question! XJ
« Reply #1 on: February 19, 2011, 04:46:59 AM »
How much lift do you have in the front of your XJ?
It's a good idea to put in an adjustable track-bar if you are running more than 4". Some people get away with the 'ol re-drill of the stock bracket axle-side, but I'm not really a fan of this trick myself .
Try this first if you have only 2-3" of lift up front : rock the Jeep side to side by pushing against the fenders, and then push down on the bumper a couple of times to center the axle.
You can also have a friend saw the steeringwheel (slowly) while you try to align the track-bar.
It's still a wise investment to get a quality track-bar though.
HTH
« Reply #2 on: February 19, 2011, 08:32:20 AM »
Every time you have the the TB off check the lower bolt hole for elongation. I have seen many a D30 with the lower hole elongated, even on stock rigs. I like to weld a thick washer on the outside hole of the lower bracket to keep it from wearing.
Offline 88xj
« Reply #3 on: February 19, 2011, 08:36:30 AM »
a track bar does just that keeps the axle some tracking so when you remove it the axle will shift. get a come along and pull the axle over to where you can get the bolt and bar in. if you only went up a few inch's then you don't need to get a new one that can come latter down the road
Offline halfcRoOk
« Reply #4 on: February 19, 2011, 09:40:12 AM »
Alright, thanks for the tips! i have a 2" spacer in the front, I removed the old factory spacers, they were going, soon soon I will get a 3.5" RE lift kit and will invest in many useful things! thanks guys, always very usefull information!!
1991 Cherokee 4x4
1988 Cherokee 4x4
