Author Topic: Transfer case  (Read 1678 times)
Offline Whips17
Transfer case
« on: March 12, 2011, 10:03:29 PM »
How much flex should my Dana 300 have? My shifter moves 3-4 inches up and down when I give her lotes of throttle
80 CJ-7 350 chevy, 8000 Warn winch,  33/12.5 R15 Cooper STT,  True Trac front & Rear,
Re: Transfer case
« Reply #1 on: March 12, 2011, 10:58:39 PM »
? Your transfer case shifter? Id think none... Are all your mounts solid under the jeep?
« Last Edit: March 12, 2011, 11:00:34 PM by tliguana »
Offline rangerdanger
Re: Transfer case
« Reply #2 on: March 12, 2011, 11:07:38 PM »
Check the mount on the drivers side of the tcase, should have a bolt with a couple of bushings to keep the case from turning under load. Heres a pic
If thats missing, your tcase shifter will move side to side as you hit the throttle.
Lethbridge Coulee Kruzer
Offline Whips17
Re: Transfer case
« Reply #3 on: March 13, 2011, 06:27:54 PM »
Ill chk that out thks.  :)
