Author Topic: HOOD COOLER  (Read 2249 times)
Offline FirstTimer
  • Gettin there!
HOOD COOLER
« on: March 24, 2011, 04:32:01 PM »
Anybody have this? Or is the application in calgary not worth it? IT looks pretty cool too!
http://www.atozfabrication.com/store/Jeep-Cooling/
Offline Knox
Re: HOOD COOLER
« Reply #1 on: March 24, 2011, 07:08:44 PM »
http://shop.poisonspyder.com/Jeep-TJ-LJ-Hood-Louver-p/14-53-010.htm
Poison Spyder makes one too... but this is something you can do yourself with a pick axe and some liqour
2003 TJ
Offline AV.NINE
Re: HOOD COOLER
« Reply #2 on: March 24, 2011, 07:22:03 PM »
Hahaha! WIN!
Offline scott slade
  • Amboy... Route 66
Re: HOOD COOLER
« Reply #3 on: March 24, 2011, 07:22:56 PM »
Using bacon grease helps the pick axe slide through the hood....  seriously... I know cooling vents seemed to help my old XJ... these are "cool"...    8)
2005 LJ, Six Speed,
 16" Moab Rims
Re: HOOD COOLER
« Reply #4 on: March 24, 2011, 09:11:54 PM »
Get out your favorite firearm and add some speed holes while you are at it.
Offline FirstTimer
  • Gettin there!
Re: HOOD COOLER
« Reply #5 on: March 25, 2011, 10:21:14 AM »
Seems like the general consensus is this things are useless...I still think they look damn cool though and way cheaper than an AEV hood.
Offline scott slade
  • Amboy... Route 66
Re: HOOD COOLER
« Reply #6 on: March 25, 2011, 11:50:19 AM »
Remember ... That's part of the fun of owning a Jeep...  You can do what you want to do to it.  Any advice is good. 8)
2005 LJ, Six Speed,
 16" Moab Rims
Offline FirstTimer
  • Gettin there!
Re: HOOD COOLER
« Reply #7 on: March 25, 2011, 12:13:51 PM »
Agreed! Thanks
Offline rws
  • Stump Grinder
Re: HOOD COOLER
« Reply #8 on: March 25, 2011, 01:01:41 PM »
This sounds like fun! ;D
Many jeepers use the $5 solution which is a hood vent from a mid 80's LeBaron.
Re: HOOD COOLER
« Reply #9 on: March 25, 2011, 02:19:12 PM »
Thats still a boatload of mone
That is still a LOT of money for an engine that does not need any cooling. Maybe rip out the insulation from under the hood?
If you like it and you have the money for it, than all else is moot. Just be prepared to answer everyone that asks, "What bigblock are you running?"
Offline JENSSEN
    • Racing For The Cure
Re: HOOD COOLER
« Reply #10 on: March 25, 2011, 02:43:30 PM »
www.racingforthecure.ca
Offline LLYJ
  • carport ghetto fab
Re: HOOD COOLER
« Reply #11 on: March 25, 2011, 03:20:46 PM »
Took my YJ through death valley at 44 degrees and never overheated, stock 4 cyl and rad at the time - stock cooling works pretty good.
That said, it would nicely cover my hoods "stupid dent" (from flipping it up on the windshield frame and not using the prop)
05 Dodge 2500HD hauler
