Author Topic: This is too much!  (Read 1720 times)
This is too much!
« on: April 06, 2011, 08:52:18 PM »
I cursed lightly at your use of torx headed bolts for my tailgate.
I swore loudly and threw things at your genius idea of using an internal torx on my drive train.
We were getting along ok removing my roll cage with your T-45 and then you did THIS TO ME?!?!
Chysler how could you? A tamper proof T-45? Friends off.  >:(
Speaking of which anyone got one I can borrow? I'll probably get fed up and grind the head off by around 11am tomorrow.
Offline AV.NINE
Re: This is too much!
« Reply #1 on: April 06, 2011, 09:11:09 PM »
I have one, Ill have to find it tomorrow though.
« Reply #2 on: April 06, 2011, 09:31:01 PM »
Cool, Thanks. I'll give you a call if I decide not to show Chrysler what I think of their "good ideas" with my grinder.
Offline cuzican
« Reply #3 on: April 06, 2011, 11:29:55 PM »
I have the tool and still had issues with some of these on my cage - welded nuts on to get them out.
Offline Knox
« Reply #4 on: April 07, 2011, 07:47:56 AM »
the security bolts are starting to get really random... ie this one I spotted the other day at Mcmaster-Carr...
2003 TJ
« Reply #5 on: April 07, 2011, 09:09:20 AM »
Looks like a Robertson head that didnt make the grade. Someone just capitalized on their mistake ;)
« Reply #6 on: April 07, 2011, 09:11:49 AM »
Spend the 6 bucks at princess and buy a set...............
Offline LLYJ
  • carport ghetto fab
« Reply #7 on: April 07, 2011, 12:01:02 PM »
Against every principle of good mechanics - I took a TJ cage apart with a big mutha set of vice grips last summer
PS I drilled my own t-45  - and it broke, which got a sideways look from our snappy rep when I traded it in LOL
05 Dodge 2500HD hauler
« Reply #8 on: April 09, 2011, 12:39:38 PM »
Thought about vice grips, ended up using a hammer and chisel to spin them out  ;D
