Author Topic: HID kits..  (Read 2297 times)
Offline IgniteTJ
HID kits..
« on: April 08, 2011, 12:56:24 PM »
Hey all, so I'm looking to find 2 decent HID kits and I don't know much about them or what brand to even go with.. I need a kit for H9 bulbs and one just for some 9005 bulbs
Offline Raspberry
Re: HID kits..
« Reply #1 on: April 08, 2011, 01:21:41 PM »
www.danielsternlighting.com
Read, soak in, understand :)
He also sells bulbs and such.
Offline parabs
Re: HID kits..
« Reply #2 on: April 08, 2011, 09:14:32 PM »
http://www.jeepforum.com/forum/f9/h-i-d-s-my-tj-wow-842999/
before and after on a TJ, and 90 pages of subsequent replies.
2000 TJ Sahara - Sold
Offline yyc_tbird_sc
Re: HID kits..
« Reply #3 on: April 08, 2011, 09:50:23 PM »
FYI.....you are asking for the police to pull you over with HIDs on your rig. If they didn't come stock, then they're illegal. No one makes a DOT HID kit for any vehicle, this is because you can't go changing the style of light (incandescent - HID) on a vehicle. The police are starting to crack down, and I know a few of the traffic guys have started impounding for them. If you have anything else that may be questionable on your rig (ie mudflaps, fenders, etc), then I wouldn't suggest it as you're asking for them to look at you a whole lot more.
The light output from an HID bulb is completely different than that of a regular bulb. When a retrofit HID bulb is put into a standard housing, the light is not reflected the same way. A proper housing is needed for HID bulbs otherwise all that happens is that you have light going everywhere. This is often mistaken for having a better bulb as you can "see alot more" or "the road is lit up better".
I know that there are all types of "offroad use only" items out on the market, but there are alot of places that are selling HID retrofit kits and downplaying how illegal they are. I am not innocent when it comes to using an "offroad use only" item on a vehicle I've owned, but these kits blind oncoming drivers and pose a big safety risk.
Sorry....just my .02. I'm jumping off my soapbox.
Re: HID kits..
« Reply #4 on: April 09, 2011, 08:49:32 AM »
If you want brighter lights then.
    Upgrade your wiring harness to 10 or 12 gauge wire with new 30 amp relays. One relay for high beam and one for low beam.
    Go to the higher wattage bulbs.
Try ed all of the bubs and conversion listed in the link in the second post and stern is right The fat boyz, hyper white , hid bulbs all say brighter but when the rubber meets the road you can not see farther down the road at night then with out the upgraded wiring harness and higher output bulbs. Those aftermarket bulbs that say 55 w = 85 w are false advertising . All they are are bulbs with filters on them that project a whiter light not a brighter light. The reliability of those aftermarket lights make it a safety concern as well as if you are driving on the highway at night the bulbs will fail with out notice leaving you stranded on the highway with out head lights. Ask me how I know.
Re: HID kits..
« Reply #5 on: April 09, 2011, 04:12:22 PM »
As others have said, if you want brighter lights then upgrade your halogens.
#1. Heavy wiring harness and relays
#2. Good quality H4 bulbs 55 watts is just fine. Anything more than that really shouldn't be used on-road.
#3. Replace your original headlights (the reflectors and lenses) with E-code Hella or Cibies
Do those three things, and you'll be happy with your lighting.
