Author Topic: SWR Meter?  (Read 1587 times)
Offline Chupacabra
  • Primero
SWR Meter?
« on: April 12, 2011, 08:38:33 PM »
Just ordered in a few parts from Northridge 4x4, those being an ARB Air compressor, some JKS disco's, and a CB set-up. Getting excited for the next trail run for sure :P
So, the air compressor and the disco's were a pretty easy set-up, and I'm planning on installing the CB over the weekend however... Anyone have a SWR meter, and know how to use it? Or at least know where one could be found? CB's are pretty new to me.
Thanks!
2010 Jeep Wrangler Unlimited - Islander Package
Offline Dagoose
Re: SWR Meter?
« Reply #1 on: April 12, 2011, 09:34:24 PM »
Take it to the road king. The the guy that runs the cb shop in there will tune it for $20 and it takes him 2 minutes.
Offline .:.Dingman.:.
Re: SWR Meter?
« Reply #2 on: April 12, 2011, 09:41:12 PM »
I do believe his name is Dean.
Dingman
Offline Jrama
Re: SWR Meter?
« Reply #3 on: April 12, 2011, 10:08:26 PM »
A SWR meter should cost you around that much. Plus CB setups do go out of tune after a little anyway. I'd invest in a swr meter, they are dead simple to use (aka 2 min tune).
Check out this link they have tons of useful info.
What swr is and why you need to tune:
http://www.rightchannelradios.com/pages/cb-antenna-tuning-and-swr-explained-pv-c0-58.html
How to tune your antenna:
http://www.rightchannelradios.com/pages/cb-antenna-tuning-guide-pv-c0-61.html
Just get a cheap swr off ebay or something it's a way better option then bringing it somewhere. You should be checking swr readings regularly anyway to make sure everythings runnin alright
« Last Edit: April 12, 2011, 10:11:25 PM by Jrama »
Re: SWR Meter?
« Reply #4 on: April 12, 2011, 10:32:45 PM »
If this is the case he has cut his rate by more than half. The last time I was there he wanted $35 just to look how I had installed the stuff I bought FROM HIM and tell me if it was right.
Chupacabra, I have an SWR meter you can borrow. Just PM and we'll set something up.
Re: SWR Meter?
« Reply #5 on: April 12, 2011, 11:27:49 PM »
Myself and Knox both have one as well if ya need ;)
Offline jeepjones
Re: SWR Meter?
« Reply #6 on: April 13, 2011, 03:32:22 AM »
There's ton's of info available on the net on how to use an SWR meter, it's worth the $30 it's costs to buy one and learn how to do it yourself.
Offline Knox
Re: SWR Meter?
« Reply #7 on: April 13, 2011, 08:49:27 AM »
What Simon is REALLY saying, is he has two meters, one being in his Jeep the other in my garage. :P haha
2003 TJ
