Author Topic: 31 x10.5 to 33x10.5  (Read 1719 times)
Offline dogman
31 x10.5 to 33x10.5
« on: April 13, 2011, 08:20:22 AM »
Last year I had 31x10.5 on my cj8 with 272 gears.I change out my diff for 307 gears.I now have a chance to purchase a set of BF goodrich mt k2
at a real good price 33 x 10.5.The questions is by installing 33 x10.5 put me back to the same as 31x10.5 with 207 gears.Also will my
tires fit without adding a body lift. I have a 2 1/2 lift and a 1/2 inch shackle lift.Also will it kind of look funny with 33 's being 10.5
thanks for your time
Re: 31 x10.5 to 33x10.5
« Reply #1 on: April 13, 2011, 09:30:28 AM »
The rule of thumb I learned was for ever 1" in diameter you increase you effectively loose 0.1 in your gear ratio.  As for the skinny 33s, lots of people run the 285/75/16s which translate into 33x11, so they will not look terrible
Offline dogman
« Reply #2 on: April 13, 2011, 09:52:40 AM »
Thanks for the reply.Does anyone know if I will have to install a body lift to make them fit.
                                          Tks
« Reply #3 on: April 13, 2011, 10:26:20 AM »
I would test them out and see, but you might need a 1" body lift which is not a problem or you will have to adjust your bump stops.
YoungFluff03TJ
« Reply #4 on: April 13, 2011, 11:28:37 AM »
i have 33-10.50 bfg ATs on my tj.
Jrama has same size km2 on his rig.
they look awesome, and perform well. If you want a pic i can email you as i dunno how to post on here (form a mac. additional options does not pop up the attach image thinger)
Offline Jrama
« Reply #5 on: April 15, 2011, 11:15:52 AM »
A 33x10.50 is better on the road (winter too), comparable on most terrains, worse in mud. As far as looks are concerned...(Here I may be a little biased) I think they look really good on modestly lifted jeeps, they give that military jeep type look with narrow tires. Half the time most people won't even notice the difference between them and normal 12.50's.
On a CJ with modest lift I'd think it would be great, its a lighter tire size (less rubber), as well the KM2 is one of the lightest MT tires around. When I go the 35" tires I am buying KM2's again without a doubt.
