Author Topic: swingout latches  (Read 2215 times)
Offline apeman
  • not as grumpy
swingout latches
« on: April 19, 2011, 03:41:40 PM »
Looking for a good strong,possibly adjustable latch for my swingout tire carrier. Any suggestions?
Getting grumpier every day.
Offline Tyn Pow
Re: swingout latches
« Reply #1 on: April 19, 2011, 05:43:20 PM »
Gregg's would have something
Offline Knox
« Reply #2 on: April 19, 2011, 07:28:49 PM »
There are a few styles I'm personally considering, something like this seems pretty common
http://www.mcmaster.com/#draw-pull-latches/=by890t
alternatively I've been looking at this style of a latch, so I can just swing it shut, then have to pull it up to swing open.
a "Spring Loaded Slide Bolt" (all the way at the bottom)
http://www.mcmaster.com/#catalog/117/2942/=by8fl4
*not sure if McMaster will let me hot link the images, so if they don't show just go to the website. But Yeah Greggs should have very similar stuff.
2003 TJ
« Reply #3 on: April 19, 2011, 09:17:58 PM »
i had one similar to that first one knox.
it broke a week after i had it........ last year i literally ratchet stapped the tire carrier closed.  i've resorted to a nut and bolt to keep mine closed........... yes i use a ratchet and a wrench to open/close it..............
easier and hopefully it won't swing open on mcleod again and almost wax a civic.........
« Reply #4 on: April 19, 2011, 10:14:15 PM »
I used that first style on my swing out carrier. Been good for a year now. Got it at Greggs Distributors. Very happy with it.
Offline JENSSEN
    • Racing For The Cure
« Reply #5 on: April 19, 2011, 11:40:15 PM »
I have those at Acklands if anyone needs one,...
www.racingforthecure.ca
Offline apeman
  • not as grumpy
« Reply #6 on: April 20, 2011, 12:31:11 AM »
Hey jens,I need one...lemme know how much and I will pick it up this week.
Offline LLYJ
  • carport ghetto fab
« Reply #7 on: April 21, 2011, 09:42:59 AM »
I picked up a couple adjustables in the surplus section at PA - they are rough and you would need to whip up a bracket and link but I may use one on my swing out (I bought em for left andf right park brakes originally)
They are the same as park brakes in old internationals and landcruisers - just another option..
05 Dodge 2500HD hauler
Offline JENSSEN
Offline apeman
  • not as grumpy
« Reply #9 on: April 21, 2011, 02:45:41 PM »
Sweet, thanks for your help Jensen... 8)
