Author Topic: some noob questions  (Read 931 times)
Offline lizard230
some noob questions
« on: May 03, 2011, 01:09:44 AM »
first of all. tj doors on a yj, possible?
second, does a stock 87 yj have air conditioning?
If so, how can i turn that into onboard air
if not, whats an easy way of putting OBA into my YJ?
2000 TJ
Re: some noob questions
« Reply #1 on: May 03, 2011, 08:00:21 AM »
first, no TJ doors ain't gonna work on YJ. latches are different.
second: don't know it may or may not have it.
third, if it DOES have AC you can gut the AC system and run it a tank. i just finished mine, its slick.
if you don't have OBA, ya gotta fiddle with brackets and crap off an XJ to make it work.  thats how mine is setup. i couldn't tell ya what came off what though.
if you have AC, you can come take a look at my setup anytime
Offline Evil-Jeep
« Reply #2 on: May 03, 2011, 08:16:50 AM »
JP mag ran an article a while back on how to swap TJ doors to a YJ, if I remember correctly the latches need to be changed over as well, and you may loose the ability to use your factory hard and soft tops.
Google - TJ doors on YJ for more info
Offline .:.Dingman.:.
« Reply #3 on: May 03, 2011, 09:02:16 AM »
X2 with what John said I wanted to keep Ac in my zj so I picked up a viair o.b.a setup, you could also mess around finding a York compressor. I might have an air tank kicking around in my garage message me if interested.
Dingman
« Last Edit: May 03, 2011, 09:11:46 AM by .:.Dingman.:. »
