Author Topic: Carbos Steel Shackles  (Read 1555 times)
Offline raf2379
« on: May 05, 2011, 08:07:44 PM »
know your shackle strength. Max Safe Single Vertical Pull
STOCK DIAMETER          INSIDE WIDTH            PIN DIAMETER      MAX SAFE WORKING LOAD
               1/2"                                  13/16"                            5/8"                                           4000lbs
               5/8"                                  1 1/6"                             3/4"                                           6500lbs
               3/4"                                 1 1/4"                             7/8"                                            9500lbs
               7/8"                                 1 7/16"                          1"                                                13000lbs
                1 "                                    1 11/16"                        1 1/8"                                        17000lbs
               1 1/8"                              1 13/16"                        1 1/4"                                        19000lbs
               1 1/4"                              2 1/32"                          1 3/8"                                        24000lbs
               1 3/8"                              2 1/4"                            1 1/2"                                         27000lbs
               1 1/2"                              2 3/8"                            1 5/8"                                         34000lbs
               1 3/4"                              2 7/8"                            2"                                                50000lbs
                2"                                    3 1/4"                             2 1/4"                                        70000lbs
Offline silverfox
  • drawrof og nac enoyna
Re: Carbos Steel Shackles
« Reply #1 on: May 05, 2011, 08:16:53 PM »
Good info.
2018 JLU Lifted on 37's
Offline yyc_tbird_sc
« Reply #2 on: May 07, 2011, 01:02:26 AM »
Where did you get that info from? If it was from a manufacturer...then it's only good for shackles from just that company. Any shackle worth using will have a WLL (working load limit) or SWL (safe working load) cast right onto the body. If it doesn't, don't use it.
Offline raf2379
« Reply #3 on: May 07, 2011, 07:40:43 AM »
it came out of my tally book, cheet sheet. these are the standard load ratings of shackles used in the oilfield for those sizes, but your correct that some manufactures would have their own rating stamped onto the shackles and some yeld a higher rating WLL. this is a basic guide line and other manufactures would either rate their shackles the same or higher if better alloy is used. I believe ICC 7/8" shackle is rated at 14500lbs and CM big orange rates their 7/8" shackle at 18700lbs.
