Author Topic: front wheel bearings  (Read 1886 times)
Offline mycat99
« on: June 06, 2011, 05:00:53 PM »
last night i started to get a nice grinding noise in my jeep .jacked it up and saw i have about a good 1/4 inch play on front router .this will be first  time change  them on this jeep .are they pressed in ?or can i do it if can find a realy big wrench? shops i called looking for around 500.
Offline mycat99
Re: front wheel bearings
« Reply #1 on: June 06, 2011, 05:04:01 PM »
woops forgot say its a 1993 jeep yj
Offline .:.Dingman.:.
« Reply #2 on: June 06, 2011, 05:17:47 PM »
you buy the wheel bearings soak all the bolts in liquid wrench and I'll show you how to do it.
all for lunch and a cold beverage.
Dingman
Offline Marco
« Reply #3 on: June 07, 2011, 07:21:21 AM »
if your jeep is lifted with bigger and or offset wheels the front bearings seem to go faster. i buy mine online for waaay less money then locally. i would try that if your not in a hurry and can wait a week for shipping. dingman definetly good idea on the liquid wrench cause they can be a huge pita
locked and loaded
Offline mycat99
« Reply #4 on: June 10, 2011, 03:10:28 PM »
i just tryed taking off some bolts and bent my cheap breaker bar .can jeep be driven across town even with it making noise or better to get towed?
« Reply #5 on: June 11, 2011, 09:51:25 AM »
Where do you order them from online?
Offline mycat99
« Reply #6 on: June 11, 2011, 12:59:01 PM »
i got the cheap ones from napa . they where 75.00 my  cost
« Reply #7 on: June 11, 2011, 01:17:07 PM »
I snapped a 1/2" Snap on breaker bar first time I tried to get that hub nut loose. Went and bought a Craftsman 3/4" breaker bar with a 3/4 to 1/2 reducer and in 10 years I havn't  been able to break that sucker!
Now that I have a garage, compressor and high quality impact its a breeze.
Offline gman
« Reply #8 on: October 25, 2011, 08:32:06 PM »
I have gotten a lot of different bearings from Transmission supply in Calgary. Good quality and they can usually cross reference the original to a better one. Not real sure if they have what you want but it's worth a shot. All the best.
Offline FirstTimer
  • Gettin there!
« Reply #9 on: October 25, 2011, 09:40:38 PM »
I am also interested what website you get your bearings from?  And do they hold things till pay day?  ::)
Offline CatSplat
« Reply #10 on: October 25, 2011, 11:22:25 PM »
I bought my Timken wheel bearings from RockAuto for ~$85 each. Local parts place wanted $285  each for a comparable SKF bearing, so RockAuto it was. I always order a few space parts (U-joints, gaskets, A/C seals, etc) to make shipping worth it.
Jeep of Theseus
Offline Black Betty
« Reply #11 on: October 26, 2011, 08:02:11 AM »
I used a 36mm socket and 36" 3/4 drive breaker bar from pa for about $40-$50.  Took that and a torch plus a can of pb blaster to get that nut out.  To remove the unit bearing after the nut and three 13mm twelve point bolts were off, I did the bolt trick to get the unit bearing out with ease.  You spin the axle till the outer shafts ears are parallel to the ground, place a bolt or socket that's long enough between the outer ear and inner "c" and have a buddy turn the steering wheel left until the unit bearing pops out.  (if it's the passenger side bearing that's gone).
This was on a xj Dana 30, not sure if it will work the same on a vacuum disco.  You might want to change the u joint while you have everything open too, seeing as it's only another $35.
FYI, partsource wants $165 for a Dana 30 unit bearing.
Stupid hurts
Offline jeepjones
« Reply #12 on: October 30, 2011, 01:46:23 PM »
Go to KINGSWAY AUTO PARTS on 17th ave S.E, $50 each for the unit bearings and $14 for the Ujoint at Pat's.
« Last Edit: October 31, 2011, 10:59:59 AM by jeepjones »
