Author Topic: Armchair Mechanic needed!  (Read 1285 times)
Offline Evil-Jeep
« on: June 08, 2011, 05:53:49 PM »
On my way home today I was pulling thru some soft ground and went to throw the jeep in 4wd.
no problem for the first 2 feet then I had no gears, seemed like the Tcase was in Neutral.
Pulled over shut it down took a look under neath - nothing out of the ordinary. Jumped in put it back in 2wd started it and drove just fine. Pulled in the drive way put it back in 4hi and noticed |I had no indicator light but seemed 4wd was engaged.
I am thinking the linkage is out on the t-case, should I run with this or should I be more worried.
My morning commute is from Calgary to Crossfield, and I wiil not have time to get under the jeep until the weekend.
Stock 03 TJ with 4.o and manual trans.
Thoughts?
Re: Armchair Mechanic needed!
« Reply #1 on: June 08, 2011, 06:17:48 PM »
t/case linkage may need an adjustment. if i recall all you do is put it in 4low, loosen the adjuster bolt, and put it all the way to 4low. tighten hold down bolt.
Offline .:.Dingman.:.
« Reply #2 on: June 08, 2011, 07:36:32 PM »
1/2 and 9/16 use the 1/2 to loosen shift linkage then use the 9/16 wrench to manually shift the t case move the shifter and re-adjust.
Dingman
Offline Evil-Jeep
« Reply #3 on: June 08, 2011, 08:05:26 PM »
thanks all!
