Author Topic: Cherokee Noise  (Read 1861 times)
Offline Gorg
Cherokee Noise
« on: June 14, 2011, 04:54:38 PM »
Tried to start my '99 Cherokee this afternoon after its been sitting for 3 weeks while ive been away. When i started it, it seems to turn over but its makes quite a fuss, namely a very loud and on going squeal, i didnt leave it on for long for fear that ill damage something. Anyone have any suggestions or questions for a proper diagnosis?
I dont have much mechanic know-how and im not too keen on getting it towed and serviced by a mechanic seeing that i just got back home, but its not out of question as i do need it for work soon.
Any help is greatly appreciated.
'15 Ram 1500 Express
'06 Audi A4 B7 quattro
'08 Jeep XK Limited
'06 Jeep TJ Sport
'99 Jeep XJ Sport
Offline 03Jeeper
Re: Cherokee Noise
« Reply #1 on: June 14, 2011, 05:03:31 PM »
Possibly be the drive belt or some surface rust on the pulleys? Could be a bad bearing in the idler pulley, alternator, power steering.
« Last Edit: June 14, 2011, 05:08:24 PM by 03Jeeper »
Offline Gorg
Re: Cherokee Noise
« Reply #2 on: June 14, 2011, 05:12:29 PM »
The belt doesnt move when its been started, not sure if i should use an oil or what-not or try to move things by hand.
'08 Jeep XK Limited
'06 Jeep TJ Sport
'99 Jeep XJ Sport
Offline slimbeam
Re: Cherokee Noise
« Reply #3 on: June 14, 2011, 05:22:53 PM »
Loosen off the belt and try to turn the different pulleys by hand and see  what is seized, if thebelts not turning at all it probably needs tightened or replaced  if its wore a spot around a pulley
« Last Edit: June 14, 2011, 05:27:21 PM by slimbeam »
Offline Gorg
Re: Cherokee Noise
« Reply #4 on: June 14, 2011, 08:11:11 PM »
Yah im gonna sleep on it, havent slept for a solid 2 days. Thanks for the info guys ive got a good idea of what to do now.
'08 Jeep XK Limited
'06 Jeep TJ Sport
'99 Jeep XJ Sport
Re: Cherokee Noise
« Reply #5 on: June 14, 2011, 10:31:10 PM »
what do you mean 'the belt doesn't move when i start it'  do you mean the belt is not moving on the pulleys while the engine is running?
how long did you run it for?  belts squeel sometimes. the vehicle is 12 years old.......... its what some would call a quirk ;)
how tight is the belt?
Offline Gorg
Re: Cherokee Noise
« Reply #6 on: June 15, 2011, 08:56:26 AM »
The engine pulley spins and makes a nice burning smell, as it rubs the belt i assume.
I ran it just a few seconds at a time maybe 10 times, im not sure what would break if i leave it on. Haha, Yah it has a few of those.
Im not sure how to answer, how do i check that?
« Last Edit: June 15, 2011, 09:49:42 AM by Gorg »
'08 Jeep XK Limited
'06 Jeep TJ Sport
'99 Jeep XJ Sport
Re: Cherokee Noise
« Reply #7 on: June 15, 2011, 09:00:26 AM »
pop the hood and fire it up.  find the screech. if it goes away, drive the jeep.
i'm guessing you have a siezed idler pulley and thats why it stinks and is squeeling.  watch all your pulleys on the engine. if one is not moving, or is wobbly, or grinding,et you know.
to test your belt tension, press on the belt. you should not get more than 1/2" of movement.
