Author Topic: Build-down(?)  (Read 2416 times)
Offline Worsley
Build-down(?)
« on: June 16, 2011, 10:37:43 AM »
Hey guys. I used the search but have come up empty.
I have a 1998 XJ 2 door with a 3 inch lift, and 30x9.5.
Rims are 15x8 with a 3.75" back spacing. I am removing the lift,
And have a question in regards to what I have to do first.
When I remove the lift, and put it back to stock height,
Will the 30x9.5 tires with those rims fit?
Or do I need to get new tires first, and then remove the lift?
Offline esi
Re: Build-down(?)
« Reply #1 on: June 16, 2011, 02:00:52 PM »
tires should fit, but the wheel offset is probably too much. A set of factory wheels should tuck the tires in where they belong.
Formerly of Boots & Boost Inc
Re: Build-down(?)
« Reply #2 on: June 16, 2011, 02:09:27 PM »
I believe with that offset and tire size, the tires will rub in the rear especially if the stock leafs you are installing at sagged at all
Offline halfcRoOk
Re: Build-down(?)
« Reply #3 on: June 16, 2011, 02:17:56 PM »
They Will definatly rub! especially in the front! when you turn! on the fenders! haha, and in the rear, as soon has you hit a bump or have weight in the back, the tires will rub on plastic inside the wheel wells! I had a 2" lift and with 31" and black steelies with a pretty big offset and rubs in the back and front, now I got 3" in the back and cut the fenders up front!
1991 Cherokee 4x4
1988 Cherokee 4x4
1978 Austin Mini 1000
Also looking for a Comanche!
Offline Worsley
Re: Build-down(?)
« Reply #4 on: June 18, 2011, 11:30:13 AM »
Ok that's what I thought. Will those rims cause a set of 235/75/15 to rub on stock suspension? I mean that's only like 2-3 inches total of tire change and I'm coming down 3 inches.
Offline Worsley
Re: Build-down(?)
« Reply #5 on: June 21, 2011, 05:02:33 PM »
bump?
anyone??
Offline esi
Re: Build-down(?)
« Reply #6 on: June 22, 2011, 01:00:35 AM »
Those tires will rub with fenders with offset wheels and a little flex
