Author Topic: gear oil type?  (Read 1384 times)
Offline mycat99
gear oil type?
« on: June 20, 2011, 04:40:25 PM »
hello i have a ford 8.8 rear diff in my jeep but do not know what type of gear oil to use . my oil is realy dirty and would like to change it
Re: gear oil type?
« Reply #1 on: June 20, 2011, 05:01:46 PM »
I just use 80w90 standard dino oil.  I have an ARB so i don't know if you have a limited slip and if the ford LS requires an additive.
Re: gear oil type?
« Reply #2 on: June 20, 2011, 10:27:27 PM »
if you have a ford limted slip differential you will need the proper ford lsd additive. or a diff fluid that has the additive in it. the ford additive is a small bottle of blue fluid that stinks like you wouldnt believe.
Offline chiefwannaburn
Re: gear oil type?
« Reply #3 on: June 23, 2011, 10:46:13 PM »
this stuff is very important my friend changed his gear oil in his ford and it only lasted 2months till the diff had to be completly replaced
GIT-R-DONE
WHOOOOOOOOOO
