Author Topic: 3" lift shocks on a stock height XJ?  (Read 1860 times)
Offline Worsley
« on: June 29, 2011, 10:16:36 PM »
hey guys, will shocks meant for a 3 inch lift, work on a jeep with stock suspension?
or will i be running into bottoming out issues?
thanks guys!
any help is appreciated!!
Re: 3" lift shocks on a stock height XJ?
« Reply #1 on: June 29, 2011, 11:00:30 PM »
for a rig that never sees a trail they should be fine.
« Reply #2 on: July 02, 2011, 12:45:28 PM »
If they have less the 3" of shaft showing, they will bottom a lot.
I doubt they will fit right. Stock shocks are very small.
« Reply #3 on: July 02, 2011, 01:04:13 PM »
I was at Modern Motors in January and found out that Rancho has the same part number for it's XJ shock for 0 " to 3 " of lift.
HTH
